First fire on Magnum...duh!! #336533
06/02/09 06:50 PM
06/02/09 06:50 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
'94 5.9l Magnum in my 67 Barracuda
Ok...this afternoon was the first turn of the engine, I was not too wooried as I kept the starting system from the 67, so the engine turns on key
Next I wanted to see if there was saprks to the plugs...but no sparks while cranking....that is my problem for start....and no current to the coil
FRom the PCM, I installed the auto shut down relay and pump realy, supplied the PCM with 12v feed....I did not hold the starter relay from the '94, and the Park/neutral switch is not connected to the trans, I kept the 67 904 switch to go with the car wiring...
Can anyone give me several ideas to where I missed ?
Daniel
Re: First fire on Magnum...duh!! [Re: Wedgeman] #336534
06/02/09 07:53 PM
06/02/09 07:53 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Does the PCM has to be grounded ?
Re: First fire on Magnum...duh!! [Re: Wedgeman] #336535
06/03/09 01:40 AM
06/03/09 01:40 AM
Andrewh Offline
Andrewh  Offline
I can't say for sure for the 94, but there must have been a dozen grounds for the 2000.
One on each head, seemed like front and back, one in the back of the block, and a couple of others I don't remember. So my guess is yes.
Re: First fire on Magnum...duh!! [Re: Andrewh] #336536
06/03/09 09:50 PM
06/03/09 09:50 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
One more thing, after the ignition is on, the ASD realy turns off after 2-3 seconds, is this normal?
What can cause ?
Re: First fire on Magnum...duh!! [Re: Wedgeman] #336537
06/03/09 10:21 PM
06/03/09 10:21 PM
Darien Center, NY
440Bel2 Offline
440Bel2  Offline
Darien Center, NY
I believe this motor needs a crank sensor signal if you're using a '94 pcm and other parts. I know that on the Rams, the ASD will come on for a couple seconds at key on power, but will not turn back on without a crank signal.
Re: First fire on Magnum...duh!! [Re: 440Bel2] #336538
06/03/09 11:43 PM
06/03/09 11:43 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok...good info there,
I do have the crank sensor connected
Dan
Re: First fire on Magnum...duh!! [Re: Wedgeman] #336539
06/04/09 06:21 PM
06/04/09 06:21 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Any other ideas ?
Re: First fire on Magnum...duh!! [Re: Wedgeman] #336540
06/04/09 06:56 PM
06/04/09 06:56 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Are you using the 94 Sbec II ECU or something else?
Leave the gun.......take the Cannoli's....Mike
Re: First fire on Magnum...duh!! [Re: mike s] #336541
06/05/09 12:01 AM
06/05/09 12:01 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I'm using the stock '94 PCM
DAn
