URGENT broken down in tennessee
#336193
06/02/09 12:54 PM
06/02/09 12:54 PM
Installing a new flasher. All of a sdden car won't start will run with key all the way on but not without. Ignition possibly?Please call with any suggestions! 617 935 1705
Re: URGENT broken down in tennessee
[Re: Mr.Yuck]
#336196
06/02/09 01:01 PM
06/02/09 01:01 PM
nothing to undo just changed flasher.
[Re: stumpy]
#336198
06/02/09 01:05 PM
06/02/09 01:05 PM
Noo power at ballist resistor
#336199
06/02/09 01:09 PM
06/02/09 01:09 PM
no power at distributer either
#336202
06/02/09 01:15 PM
06/02/09 01:15 PM
Posts: 823 On the open road
Hrtbkr
On the open road
Assuming your ballast resistor is still good-Unplug the two wire connector from the BA and jump power from the battery there. You could get home like that. If the BA is bad, jump to the coil. That'll be good enough to get you to a parts store for a new BA. Good Luck!
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: Stanton]
#336203
06/02/09 01:16 PM
06/02/09 01:16 PM
replaced resister with my spare about an hour ago , no go
#336204
06/02/09 01:18 PM
06/02/09 01:18 PM
#336205
06/02/09 01:23 PM
06/02/09 01:23 PM
#336206
06/02/09 01:24 PM
06/02/09 01:24 PM
Posts: 7,506 Az
Crizila
Az
Assume you started @ the fuse box and all ignition related fuses are good?
Fastest 300
[Re: Crizila]
#336208
06/02/09 01:27 PM
06/02/09 01:27 PM
#336210
06/02/09 01:36 PM
06/02/09 01:36 PM
blue/white has power hot wire from batt tocoil still nothing
