URGENT broken down in tennessee #336193
06/02/09 12:54 PM
06/02/09 12:54 PM
Anonymous OP
Anonymous OP
Installing a new flasher. All of a sdden car won't start will run with key all the way on but not without. Ignition possibly?Please call with any suggestions! 617 935 1705
Re: URGENT broken down in tennessee #336194
06/02/09 12:58 PM
06/02/09 12:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd un-do what you did and get it home
Coming soon!!!!
Re: URGENT broken down in tennessee #336195
06/02/09 12:58 PM
06/02/09 12:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for power from the ballast resistor with the key in the run position.
Re: URGENT broken down in tennessee [Re: Mr.Yuck] #336196
06/02/09 01:01 PM
06/02/09 01:01 PM
Anonymous OP
Anonymous OP
nothing to undo just changed flasher.
Re: URGENT broken down in tennessee #336197
06/02/09 01:04 PM
06/02/09 01:04 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
check for spark at the plugs
Re: URGENT broken down in tennessee [Re: stumpy] #336198
06/02/09 01:05 PM
06/02/09 01:05 PM
Anonymous OP
Anonymous OP
Noo power at ballist resistor
Re: URGENT broken down in tennessee #336199
06/02/09 01:09 PM
06/02/09 01:09 PM
Anonymous OP
Anonymous OP
no power at distributer either
Re: URGENT broken down in tennessee #336200
06/02/09 01:11 PM
06/02/09 01:11 PM
Va
junkman Offline
junkman  Offline
Va
the resiter on the firewall is bad, usually above the wiper motor or to the left of it looking at the engine from the front, make a little jumper wire to get the car started and replace asap,
Re: URGENT broken down in tennessee #336201
06/02/09 01:12 PM
06/02/09 01:12 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Blown ballast resistor. Check again, with the key in the run position you should have power on one side but not the other (with a blown ballast). Better yet, check it with an ohm meter - it should have resistance - if the meter shows no movement then the ballast is toast.
Probably totally unrelated to the flasher, just coincidence.
Re: URGENT broken down in tennessee #336202
06/02/09 01:15 PM
06/02/09 01:15 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Assuming your ballast resistor is still good-Unplug the two wire connector from the BA and jump power from the battery there. You could get home like that.
If the BA is bad, jump to the coil. That'll be good enough to get you to a parts store for a new BA.
Good Luck!
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: URGENT broken down in tennessee [Re: Stanton] #336203
06/02/09 01:16 PM
06/02/09 01:16 PM
Anonymous OP
Anonymous OP
replaced resister with my spare about an hour ago , no go
Re: URGENT broken down in tennessee #336204
06/02/09 01:18 PM
06/02/09 01:18 PM
Anonymous OP
Anonymous OP
Coil replaced 2 days ago
Re: URGENT broken down in tennessee #336205
06/02/09 01:23 PM
06/02/09 01:23 PM
Anonymous OP
Anonymous OP
Sorry BA is what again?
Re: URGENT broken down in tennessee #336206
06/02/09 01:24 PM
06/02/09 01:24 PM
Az
Crizila Offline
Crizila  Offline
Az
Assume you started @ the fuse box and all ignition related fuses are good?
Fastest 300
Re: URGENT broken down in tennessee [Re: Crizila] #336207
06/02/09 01:26 PM
06/02/09 01:26 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Bue/white wire ign wire out of the firewall bulkhead. Push/wiggle check for power with key on.
Re: URGENT broken down in tennessee [Re: Crizila] #336208
06/02/09 01:27 PM
06/02/09 01:27 PM
Anonymous OP
Anonymous OP
fuses are good
Re: URGENT broken down in tennessee #336209
06/02/09 01:34 PM
06/02/09 01:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had a 69 charger that died at the beer store. It was the factory amp gauge. I hot wired it to get it home then just bypassed it. The entire car died...no nothing.
Coming soon!!!!
Re: URGENT broken down in tennessee #336210
06/02/09 01:36 PM
06/02/09 01:36 PM
Anonymous OP
Anonymous OP
blue/white has power hot wire from batt tocoil still nothing
Re: URGENT broken down in tennessee #336211
06/02/09 01:47 PM
06/02/09 01:47 PM
USA IN
E85-408 Offline
E85-408  Offline
USA IN
I had the fuseable link burn once so I just hot wired the car. I ran a wire from the battery to the resitor block. It was just that simple. Also might wanna discconect the power side of the block just incase there is a short there. Good luck
Re: URGENT broken down in tennessee [Re: E85-408] #336212
06/02/09 01:57 PM
06/02/09 01:57 PM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
check dist plug where it plugs to harness
