Those using CSR trans shield, dipstick tube problem #332139
05/28/09 11:19 PM
05/28/09 11:19 PM
Taylor, Michigan
1BadLiLCharger Offline OP
Taylor, Michigan
For some reason, my CRT dipstick tube doesn't want to seal with this latest engine swap. I never really cared for the design of this, it just seems like the rubber seal was WAY to big for the hole and the tube just kinda smooshed it in there, but somehow it sealed....until now, when I put the engine in tonight. I got it bolted to the bellhousing and it's just not doing it. Is there any other tube out there that'll work with this, or any ideas?
Re: Those using CSR trans shield, dipstick tube problem [Re: 1BadLiLCharger] #332140
05/28/09 11:29 PM
05/28/09 11:29 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
i had to bolt my dipstick to the mid plate, wouldnt fit behind the bolt and the sheild, just bent the tab around a bit and bolted thruogh the mid plate.
Re: Those using CSR trans shield, dipstick tube problem [Re: Dustedu] #332141
05/28/09 11:33 PM
05/28/09 11:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Having never seen the CRT part I am gonna assume the seal he is using is the GM grommet. If so they need to be replaced occasionally. If it is a long "grommet" then just go to the parts store and pivk up a Chevy dipstick tube seal. Pretty common part.
This is the GM part
Re: Those using CSR trans shield, dipstick tube problem [Re: Al_Alguire] #332142
05/29/09 12:07 AM
05/29/09 12:07 AM
Taylor, Michigan
Taylor, Michigan
Al, it DOES look like that...almost seems TOO big for the hole, seems like it should be a bit smaller, because without bolting it to the block it isn't even NEAR stable, at least the stock piece is in there pretty tight before you bolt it to the housing.
This GM grommet never seems tight.
Re: Those using CSR trans shield, dipstick tube problem [Re: 1BadLiLCharger] #332143
05/29/09 12:28 AM
05/29/09 12:28 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I run the CRT dipstick tube for the CSR shield...no problems here. Do you have it bolted to a bellhousing bolt hole?
Re: Those using CSR trans shield, dipstick tube problem [Re: Quicksilver440] #332144
05/29/09 12:46 AM
05/29/09 12:46 AM
Taylor, Michigan
Taylor, Michigan
Yes I do.
Re: Those using CSR trans shield, dipstick tube problem [Re: Dustedu] #332145
05/29/09 12:48 AM
05/29/09 12:48 AM
Taylor, Michigan
Taylor, Michigan
Somehow missed this post...anyways, don't have a mid plate.
Re: Those using CSR trans shield, dipstick tube problem [Re: 1BadLiLCharger] #332146
05/29/09 12:55 AM
05/29/09 12:55 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
use the Lokar flexible dipstick. you can mount the handle away from the heat of headers & it has 2 "O" rings to guarantee a seal.
Re: Those using CSR trans shield, dipstick tube problem [Re: 1BadLiLCharger] #332147
05/29/09 12:56 AM
05/29/09 12:56 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
Pat, i run one with no problems.
common problem ive seen on cars ive wrenched on is they do not put the rubber seal in the trans hole first then lube the dip stick and slide it in, they have tryed to install the dip stick with the seal on the tube and it doesnt want to seat in all the way into the trans hole and leak.
and a little to make it fit with a sheild
Bondo
Re: Those using CSR trans shield, dipstick tube problem [Re: BobsProFab] #332148
05/29/09 01:12 AM
05/29/09 01:12 AM
Taylor, Michigan
Taylor, Michigan
There's a thought, Bob.
And if that don't work, I may look into the Lokar setup.
Re: Those using CSR trans shield, dipstick tube problem [Re: BobsProFab] #332149
05/29/09 02:19 AM
05/29/09 02:19 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Bondo
I've had the CRT dipstick that was made for the CSR shield on my dartSport and it fit perfect. I tried the LOKAR and it was the absolute biggest piece of crap I ever bought.
Re: Those using CSR trans shield, dipstick tube problem [Re: ProSport] #332150
05/29/09 03:39 AM
05/29/09 03:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what problem did you have with the LOKAR set up sport? mine fits perfect, has never leaked even tho i've had it off a few times, & the fact that you can mount the handle away from headers makes checking the level very comfortable. my original tube never leaked but with the handle being so close to the exhaust made checking levels a glove only deal, them handles get hot!
Re: Those using CSR trans shield, dipstick tube problem [Re: rebel] #332151
05/29/09 07:34 AM
05/29/09 07:34 AM
west palm beach, florida
modelmakerinc Offline
My Lokar trans tube fitting was very loose and leaked. I also found even though it is a flexible design you still must mount it basically straight up or the fluid in the tube messes up the reading on the stick as it goes in and out, forget it if you want to check it after you just added fluid.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Those using CSR trans shield, dipstick tube problem [Re: modelmakerinc] #332152
05/29/09 08:14 AM
05/29/09 08:14 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I agree Lokar tubes are junk and try putting fluid in them what a joke.As far as the boots installed correctly they hardly ever leak.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Those using CSR trans shield, dipstick tube problem [Re: dusturbd340W5] #332153
05/29/09 12:23 PM
05/29/09 12:23 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I hated my Lokar dipstick too Pat. Putting fluid in was difficult, and in my car the dipstick was located just below that ridge that runs across the firewall. Busted my knuckles every time I pulled the stick.
I would get a new grommet and try Bob's suggestion.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Those using CSR trans shield, dipstick tube problem [Re: nhramark] #332154
05/29/09 03:56 PM
05/29/09 03:56 PM
an8sec70cuda Offline
No problems with my Lokar dipstick. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Those using CSR trans shield, dipstick tube problem [Re: an8sec70cuda] #332155
05/29/09 03:59 PM
05/29/09 03:59 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
No problems here with my stock dip stick
Re: Those using CSR trans shield, dipstick tube problem [Re: an8sec70cuda] #332156
05/29/09 04:02 PM
05/29/09 04:02 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Here's me trying to put my dipstick in with the CSR shield in place finally in ,,,oh yeah I forgot the
Re: Those using CSR trans shield, dipstick tube problem [Re: dartman366] #332157
05/29/09 04:10 PM
05/29/09 04:10 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
What? i dont get it? Mine slides right in in the stock position.is your engine set back?
Re: Those using CSR trans shield, dipstick tube problem [Re: cudabunch] #332158
05/29/09 04:16 PM
05/29/09 04:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
stock location, it would hit the shield hard before it would come even close to bolting to the bell housing, a little tweeking and I got it to work, I don't think they clearance the shield enough or a big enough cut out for a tube at time's.
