Those using CSR trans shield, dipstick tube problem
#332139
05/28/09 11:19 PM
05/28/09 11:19 PM
Posts: 2,070 Taylor, Michigan
1BadLiLCharger
Taylor, Michigan
For some reason, my CRT dipstick tube doesn't want to seal with this latest engine swap. I never really cared for the design of this, it just seems like the rubber seal was WAY to big for the hole and the tube just kinda smooshed it in there, but somehow it sealed....until now, when I put the engine in tonight. I got it bolted to the bellhousing and it's just not doing it. Is there any other tube out there that'll work with this, or any ideas?
Re: Those using CSR trans shield, dipstick tube problem
[Re: Dustedu]
#332141
05/28/09 11:33 PM
05/28/09 11:33 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Having never seen the CRT part I am gonna assume the seal he is using is the GM grommet. If so they need to be replaced occasionally. If it is a long "grommet" then just go to the parts store and pivk up a Chevy dipstick tube seal. Pretty common part. This is the GM part
[Re: Dustedu]
#332145
05/29/09 12:48 AM
05/29/09 12:48 AM
1BadLiLCharger
Taylor, Michigan
i had to bolt my dipstick to the mid plate, wouldnt fit behind the bolt and the sheild, just bent the tab around a bit and bolted thruogh the mid plate.
Somehow missed this post...anyways, don't have a mid plate.
[Re: 1BadLiLCharger]
#332147
05/29/09 12:56 AM
05/29/09 12:56 AM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
Pat, i run one with no problems. common problem ive seen on cars ive wrenched on is they do not put the rubber seal in the trans hole first then lube the dip stick and slide it in, they have tryed to install the dip stick with the seal on the tube and it doesnt want to seat in all the way into the trans hole and leak. and a little to make it fit with a sheild Bondo
[Re: BobsProFab]
#332149
05/29/09 02:19 AM
05/29/09 02:19 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I've had the CRT dipstick that was made for the CSR shield on my dartSport and it fit perfect. I tried the LOKAR and it was the absolute biggest piece of crap I ever bought.
[Re: modelmakerinc]
#332152
05/29/09 08:14 AM
05/29/09 08:14 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I agree Lokar tubes are junk and try putting fluid in them what a joke.As far as the boots installed correctly they hardly ever leak.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#332153
05/29/09 12:23 PM
05/29/09 12:23 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I hated my Lokar dipstick too Pat. Putting fluid in was difficult, and in my car the dipstick was located just below that ridge that runs across the firewall. Busted my knuckles every time I pulled the stick. I would get a new grommet and try Bob's suggestion.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#332154
05/29/09 03:56 PM
05/29/09 03:56 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
No problems with my Lokar dipstick. CHIP
[Re: dartman366]
#332157
05/29/09 04:10 PM
05/29/09 04:10 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
Here's me trying to put my dipstick in with the CSR shield in place finally in ,,,oh yeah I forgot the
What? i dont get it? Mine slides right in in the stock position.is your engine set back?
[Re: cudabunch]
#332158
05/29/09 04:16 PM
05/29/09 04:16 PM
dartman366
Mt. Vernon, Ohio
stock location, it would hit the shield hard before it would come even close to bolting to the bell housing, a little tweeking and I got it to work, I don't think they clearance the shield enough or a big enough cut out for a tube at time's.
