Page 1 of 3 1 2 3
727 kickdown adjustment?? #332022
05/28/09 09:54 PM
05/28/09 09:54 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Hi, car is a 67 stock 727.
I just got the car running and adjusted the kickdown linkage per the FSM.. Car shifts into high gear before I get around the corner and doesn't really act like its using the gears.. It manually shifts fine, but I know this isn't correct..I was told the band adjustment is OK if it shifts fine manually. Any help here??
I have since adjusted the vertical rod for more push and the rod to the carb, the slotted one, is just barely being pushed as per the FSM.. At full throttle the lever on the tranny does not max out in it travel. Have not driven it since doing this as I thought I would ask for help on moparts...
On a side note, I am curious why the rod to the carb is slotted and not just a hole??
Re: 727 kickdown adjustment?? [Re: minivan] #332023
05/28/09 10:09 PM
05/28/09 10:09 PM
You need to extend your linkage to where pretty much when the throttle is tipped the KD linkage is also starting to move which means the slotted rod(w it's seperate helper spring) is all the way back to where the front of the long slot is contacting the carb horizontle piece and at wot(eng off/gas pedal mashed to the floor the lever at the trans is all the way or close to all the way rearward and a non manual VB trans should not be shifted thru the gears manually.
Re: 727 kickdown adjustment?? [Re: RapidRobert] #332024
05/28/09 10:28 PM
05/28/09 10:28 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Guess I better start using that DRIVE button. I shift my 65 cable shift 727 with the buttons sometimes,am i doing it harm? Don't mean to hijack the thread,but i,d never heard that before.
Re: 727 kickdown adjustment?? [Re: RapidRobert] #332025
05/28/09 10:49 PM
05/28/09 10:49 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Thanks Robert.. I should ad that the slotted bar was just barely being pushed at idle, so I was close on it.. Aware a stock tranny should not be shifted manually, just wanted to add that to my thread concerning the band adjustment.. Tranny was rebuilt before installing it in car, so I wanna think its OK, just operator error in adjusting kickdown...
I believe I have read on here that the kickdown lever, on the tranny, should move all the way at wot.. Mine is not, it can still move maybe a 1/4 to 1/2 inch.. Is this OK?
Re: 727 kickdown adjustment?? [Re: minivan] #332026
05/28/09 10:51 PM
05/28/09 10:51 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Just to let you know, neither a 727 OR a 904 ever had "kickdown" linkage. They did however have throttle pressure linkage
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 727 kickdown adjustment?? [Re: 69L78Nova] #332027
05/28/09 10:53 PM
05/28/09 10:53 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
OK OK and sure grip not posi.....
Re: 727 kickdown adjustment?? [Re: minivan] #332028
05/28/09 11:06 PM
05/28/09 11:06 PM
That's why I mounted my HEI module up under my dist so nobody would see it. and it was (1) an aftermarket hot one & (2) given to me & that's rude to refuse a gift so I had no choice . On to business, I would want it back further some & you might want to extend the linkage & therefore the lever which will start to raise your shift points so do some trial/error testing & see where your shift points are at & what you are comfortable with.
Re: 727 kickdown adjustment?? [Re: minivan] #332029
05/28/09 11:18 PM
05/28/09 11:18 PM
hooziewhatsit Offline
That's how I started on mine. I had to lengthen the KD rod by an inch or so to get enough adjustment room. Currently, I have it so at WOT the kickdown linkage can't go any further back. Under light throttle I hit 3rd around 25-30, and a few mph higher under more throttle.
I still don't have PTK, or Full throttle kickdown for that matter either I went from a 2bbl to 4bbl, so I think the carb travel changed, so I need to adjust the linkage at the transmission.
Re: 727 kickdown adjustment?? [Re: hooziewhatsit] #332030
05/29/09 12:30 AM
05/29/09 12:30 AM
Did you have it before the carb swap
Re: 727 kickdown adjustment?? [Re: RapidRobert] #332031
05/29/09 01:08 AM
05/29/09 01:08 AM
Come to think of it, I don't think it was working then either.
Re: 727 kickdown adjustment?? [Re: hooziewhatsit] #332032
05/29/09 01:13 AM
05/29/09 01:13 AM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Seems recently that someone posted a thread on upgrading the older transmissions to PTK.. Seemed like it was a pretty simple fix with a few of the newer tranny parts.. Anyone have that thread??
Re: 727 kickdown adjustment?? [Re: minivan] #332033
05/29/09 01:46 AM
05/29/09 01:46 AM
This one?
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
(It's scary how many threads I've bookmarked )
Re: 727 kickdown adjustment?? [Re: hooziewhatsit] #332034
05/29/09 11:10 AM
05/29/09 11:10 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
OK- Call me stupid- but if you are not supposed to manually shift a stock trans, why would the factory equip so many with Slap-Stik's etc? Luci- you have some splainin to do-
Re: 727 kickdown adjustment?? [Re: Kirby] #332035
05/29/09 11:26 AM
05/29/09 11:26 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why aren't you supposed to manualy shift an automatic? I've been doing it for a lot of years with no bad results. Don't forget the select shift option in Mopars.
Re: 727 kickdown adjustment?? [Re: Kirby] #332036
05/29/09 06:20 PM
05/29/09 06:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's called an automatic transmission for a reason and it's intended to be used that way. It's not that you're never supposed to manual shift it's that you're not supposed to make a habit of it.
For one reason, obviously you'll wear out the shift linkage sooner.
For another reason, when manually shifting from 1-2 the rear band is applied and must release at each upshift; the rear band was never intended to be applied/released at each shift cycle and the release is so slow that it wears much more than it would if only used occasionally. The rear band isn't applied when in 1st gear in Drive.
Also, when slowing down to stop in Drive, the trans will downshift directly from 3rd to 1st, bypassing 2nd. If the trans is manually downshifted to 2nd often, the band will wear out sooner due to the added use drum direction issues.
Leaving it in Drive will eventually result in less wear and tear.
Re: 727 kickdown adjustment?? [Re: hooziewhatsit] #332037
05/29/09 06:32 PM
05/29/09 06:32 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
This one?
Thats the one Thanks
Which brings up the question if I bought a 71-77 valve body, would it be a bolt on project to my 67 TF?? Would the reconditioned or modified valve bodies being sold ( like at A&A) come with the PTK already on them?? Seems as if this would be the best way to get PTK with the limiter?? What do you all think???
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332038
05/29/09 06:33 PM
05/29/09 06:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's a whole lot different then your first statement. So the only problem with manually shifting it is a little wear and tear. No big thing.
Re: 727 kickdown adjustment?? [Re: stumpy] #332039
05/29/09 06:38 PM
05/29/09 06:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"a little" is a relative term.
Re: 727 kickdown adjustment?? [Re: minivan] #332040
05/29/09 07:39 PM
05/29/09 07:39 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I start by adjusting the kickdown linkage all the way when the throttle is WOT and then back it off a bit at a time until the part throttle upshift is where I like it.
Re: 727 kickdown adjustment?? [Re: Lefty] #332041
05/29/09 07:49 PM
05/29/09 07:49 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Lefty do you have the PTK valve??
Page 1 of 3 1 2 3
