Re: 440 problem [Re: firefighter3931] #328599
05/26/09 11:50 AM
05/26/09 11:50 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
So it acted the exact same with the summit cam? Summit cam is lower lift, 465/488 so I tend to think valvetrain stability is not the problem there but you never know. Will actually rev above 55 or just stop making power there?
Re: 440 problem [Re: firefighter3931] #328600
05/26/09 11:56 AM
05/26/09 11:56 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The rocker ratio could be affecting the valvetrain stability with those agressive lobes. Is he running a 1.6 rocker ratio by chance ?
Dulcich did a series of tests a few years back using an agressive flat tappet hyd cam with a 1.6 rocker and the engine wouldn't RPM.
Dwayne @ PRH has observed the same thing during dyno testing....agressive flat tappet hyd cams and 1.6 rocker ratios nose over early ; usually several hundred rpm lower than with a 1.5 rocker.
Ron
no 1.5's had stock 1st then rollers, same issues
Coming soon!!!!
Re: 440 problem [Re: DaytonaTurbo] #328601
05/26/09 11:57 AM
05/26/09 11:57 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
From the way it sounds it just doesn't go anymore.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328602
05/26/09 12:02 PM
05/26/09 12:02 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Is there a rev. limiter on the car? Disable it and make pass.
Re: 440 problem [Re: Mr.Yuck] #328603
05/26/09 12:03 PM
05/26/09 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what's that convertor flashing to ? I haven't seen rave reviews on the MP convertors ...
Re: 440 problem [Re: @#$%&*!] #328604
05/26/09 12:10 PM
05/26/09 12:10 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Here's a VooDoo cam thread ;
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Steve's comments on the first page :
"I could never get the Mopar Voodoo hydraulic cams to rpm. Tried everything, big and small block, cam swap to another brand fixed it."
Ron
Re: 440 problem [Re: JohnRR] #328605
05/26/09 12:18 PM
05/26/09 12:18 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I had one for over 3 years w/ zippy problems. Doubt it's a convert problem as they are usually a slipping problem.
Coming soon!!!!
Re: 440 problem [Re: firefighter3931] #328606
05/26/09 12:23 PM
05/26/09 12:23 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Ron
no REV limit on the car...and he had the same problem w/ the 488 summit cam.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328607
05/26/09 12:52 PM
05/26/09 12:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
then it's only 1 or 3 things , the fuel system ... he changed it , the ignition system or the CONVERTOR ....
Re: 440 problem [Re: Mr.Yuck] #328608
05/26/09 12:56 PM
05/26/09 12:56 PM
pana illinois
bigblock4x4 Offline
bigblock4x4  Offline
pana illinois
I have the next size bigger voodoo cam in my four wheel drive,I have the same problem.It is 9.7 to 1 and like you i can not figure out the reason it wont rev up.Ported 452 heads,3 inch exhaust,torker II intake and 800 cfm holley.Got 35" boggers, 4.10 gears,3800 convertor.but when i put in low lock it pulls like a *****!!!My buddy also thinks that it is a fuel problem.Dont have a gauge in the dash too really keep an eye on it.(I cant get nobody too ride under the hood too watch the gauge)
Re: 440 problem [Re: JohnRR] #328609
05/26/09 01:17 PM
05/26/09 01:17 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Ron
John how is the converter going to make an engine fall flat at 5500 or any rpm? seems to me if it was bad it would fling to 6500 and not go anywhere.
Re: 440 problem [Re: Mr.Yuck] #328610
05/26/09 02:10 PM
05/26/09 02:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
ok , nevermind on the convertor , maybe he should have put a 383 in it instead ??
what has been done with the ignition system and has he CONFIRMED fuel pressure at WOT ???
Re: 440 problem [Re: JohnRR] #328611
05/26/09 02:20 PM
05/26/09 02:20 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
it was a 383 car...69 RR. yes ignition was swapped as well..and he put a gauge on the cowl for that reason, yes pressure is good all the way down track. Wonder if it could be an air flow problem??? Never asked if he's running it w/ a air cleaner or not.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328612
05/26/09 02:25 PM
05/26/09 02:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Air cleaner , good thought , I assume he has a drop base round under the hood ? An RB with a performer RPM has little hood clearance , a drop base with a short air filter will kill air flow into the carb ...
Re: 440 problem [Re: JohnRR] #328613
05/26/09 02:38 PM
05/26/09 02:38 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
And is it a mech pump? If so, just for laffs I'd pull out the pushrod and see if it needs some er, uh, viagra.
The last thing thats a problem is the heads. I've seen the same thing with bad ring tension. Ask your buddy if he has ever overheated it. Tell him not to be shy.
Re: 440 problem [Re: RemCharger] #328614
05/26/09 02:42 PM
05/26/09 02:42 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah I can't believe I didn't ask him about the lid...I guess because the 1st thing when I get to the track is pull the lid and filter.... and yes Mech pump... the dude is very anal about his builds, I'm sure it's a new rod....lol
Coming soon!!!!
Re: 440 problem [Re: JohnRR] #328615
05/26/09 03:36 PM
05/26/09 03:36 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
