Re: 440 problem
[Re: firefighter3931]
#328600
05/26/09 11:56 AM
05/26/09 11:56 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The rocker ratio could be affecting the valvetrain stability with those agressive lobes. Is he running a 1.6 rocker ratio by chance ? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Dulcich did a series of tests a few years back using an agressive flat tappet hyd cam with a 1.6 rocker and the engine wouldn't RPM.
Dwayne @ PRH has observed the same thing during dyno testing....agressive flat tappet hyd cams and 1.6 rocker ratios nose over early ; usually several hundred rpm lower than with a 1.5 rocker. ![](/ubbthreads/images/graemlins/tongue.gif)
Ron
no 1.5's had stock 1st then rollers, same issues
Re: 440 problem
[Re: DaytonaTurbo]
#328601
05/26/09 11:57 AM
05/26/09 11:57 AM
Mr.Yuck
Brookeville, Md
So it acted the exact same with the summit cam? Summit cam is lower lift, 465/488 so I tend to think valvetrain stability is not the problem there but you never know. Will actually rev above 55 or just stop making power there?
From the way it sounds it just doesn't go anymore.
Re: 440 problem
[Re: JohnRR]
#328605
05/26/09 12:18 PM
05/26/09 12:18 PM
Mr.Yuck
Brookeville, Md
what's that convertor flashing to ? I haven't seen rave reviews on the MP convertors ...
I had one for over 3 years w/ zippy problems. Doubt it's a convert problem as they are usually a slipping problem.
Re: 440 problem
#328606
05/26/09 12:23 PM
05/26/09 12:23 PM
Mr.Yuck
Brookeville, Md
Here's a VooDoo cam thread ;
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Steve's comments on the first page :
"I could never get the Mopar Voodoo hydraulic cams to rpm. Tried everything, big and small block, cam swap to another brand fixed it."
Ron
no REV limit on the car...and he had the same problem w/ the 488 summit cam.
Re: 440 problem
[Re: JohnRR]
#328609
05/26/09 01:17 PM
05/26/09 01:17 PM
Mr.Yuck
Brookeville, Md
Ron
then it's only 1 or 3 things , the fuel system ... he changed it , the ignition system or the CONVERTOR ....
John how is the converter going to make an engine fall flat at 5500 or any rpm? seems to me if it was bad it would fling to 6500 and not go anywhere.
Re: 440 problem
[Re: Mr.Yuck]
#328610
05/26/09 02:10 PM
05/26/09 02:10 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Ron
ok , nevermind on the convertor , maybe he should have put a 383 in it instead ?? ![](/ubbthreads/images/graemlins/stirthepot.gif)
what has been done with the ignition system and has he CONFIRMED fuel pressure at WOT ???
Re: 440 problem
[Re: JohnRR]
#328611
05/26/09 02:20 PM
05/26/09 02:20 PM
Mr.Yuck
Brookeville, Md
[ ok , nevermind on the convertor , maybe he should have put a 383 in it instead ?? ![](/ubbthreads/images/graemlins/stirthepot.gif) what has been done with the ignition system and has he CONFIRMED fuel pressure at WOT ???
it was a 383 car...69 RR. yes ignition was swapped as well..and he put a gauge on the cowl for that reason, yes pressure is good all the way down track. Wonder if it could be an air flow problem??? Never asked if he's running it w/ a air cleaner or not.
Re: 440 problem
[Re: JohnRR]
#328615
05/26/09 03:36 PM
05/26/09 03:36 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
........... ![](/ubbthreads/images/graemlins/wave.gif)
