440 problem #328579
05/25/09 08:14 PM
05/25/09 08:14 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
A friend of mine has a 440. It falls falt at 5500. Background, .030 over 9:1 ish (.070 in the hole pistons), OTB E-heads (84cc), Fel-Pro's, 513 VooDoo cam, TTi headers (and 2.5 X-pipe exhaust), RPM intake Demon carb. He has swaped boxes, coils, distribs, cap/rotor carbs, fuel lines, pumps, went w/ roller rockers, swaped valve springs, you name it. It just will not pull above 5500 and is laying down a ton at the top end. Could the E-heads be causing the problems? He has a set of nice 906's he might try. If you need more info it's a 69 RR 727, 175k convert and 3.55's. So far the best he can do is 13.0 @100mph falling off.
He runs thru the pipes...could that be a problem??
Any ideas?
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328580
05/25/09 08:51 PM
05/25/09 08:51 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Just out of curiousity...what are the specs on that 513VooDoo cam?
Does it fall within the same RPM range as the manifold and gearing that he has?
The 906 head has a bigger combustion chamber and would decrease his compression.
Re: 440 problem [Re: Mr.Yuck] #328581
05/25/09 08:55 PM
05/25/09 08:55 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If the tune is good,I'd look at a possible fuel delivery problem. Does the valvetrain make noise at say 5000 rpm? Although I've run lots of Harolds solid grinds I've seen and heard first hand that instability can be a problem with the Voodoo hyd cams. It could be basecircle runout or another cause,some work fine and others don't. You could install solid lifters as a test,I'd check for basecircle runout as well.It's not the heads causing the problem but details about the valvespring seat and open pressure is important.
Re: 440 problem [Re: goldmember] #328582
05/25/09 09:00 PM
05/25/09 09:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if thats the 226/234-.494/.513 cam and its installed at 106 centerline, it ought to drop dead around 5500rpm.
Re: 440 problem [Re: lewtot184] #328583
05/25/09 09:04 PM
05/25/09 09:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The cam is degreed???
Re: 440 problem [Re: Blakcharger440] #328584
05/25/09 09:28 PM
05/25/09 09:28 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The intake is and RPM they work from off idle to around 6500. The 906's would drop maybe but he can use steel shim head gaskets and they have been milled some. Plus they have a ton of port work and I think 2.14/1.88 valves.
Advertised Duration: 268 int./276 exh.
.494 in. / .513 in.
"Basic Operating RPM Range: 1,800-6,200
Lobe Separation (degrees): 110"
Not sure about the 106* or dropping dead at 5500. It should pull to 6200 as advertised.
I though his biggest problem would have been the 3.55's. Seems to lauch well, just falls flat and no fuel problems. get's plenty and good pressure the entire run.
Coming soon!!!!
Re: 440 problem [Re: goldmember] #328585
05/25/09 09:31 PM
05/25/09 09:31 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah he's thinking about check w/ solid lifters. I should add hes a master mechanic and has build many many many BB and SB mopars and this is racking his brain.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328586
05/25/09 09:50 PM
05/25/09 09:50 PM
recent problem or since built? He has a fuel psi gauge inside the car? Will it rev to the offending point(5500)in neutral?
Re: 440 problem [Re: RapidRobert] #328587
05/26/09 09:05 AM
05/26/09 09:05 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yes his 1st cam was a Summit 488. thought it was the cam (although I suggested it was something else) Fuel was his 1st thought. It is not a fuel problem. 7.5lbs of pressure. Not sure about reving in "N"
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328588
05/26/09 09:12 AM
05/26/09 09:12 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
9 to one compression ... then with Eddy alum heads ... ...
That is an "effective" compression ratio of at or less than 8 to 1.
Re: 440 problem [Re: Mr.Yuck] #328589
05/26/09 09:16 AM
05/26/09 09:16 AM
7.5lbs of pressure.
I'd think that would be his idle reading & he IS showing several psi or more @5500 going down the strip when it acts up?
Re: 440 problem [Re: Mr.Yuck] #328590
05/26/09 09:19 AM
05/26/09 09:19 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
E-heads and 9:1? He needs BOOST!
That's the combo I'm running under my turbos. The Speed Pro 9:1 forged pistons measure out to 8.7:1 compression.
It's a decent setup. Just add PSI.
- Stu Harmon
Re: 440 problem [Re: RapidRobert] #328591
05/26/09 09:42 AM
05/26/09 09:42 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
7.5lbs of pressure.
He's fine all the way down the track... I'm just wondering if something happening in the chamber causing some flow issues???
Coming soon!!!!
Re: 440 problem [Re: feets] #328592
05/26/09 09:43 AM
05/26/09 09:43 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
That's what I keep telling him.. I ran the speed pro's (cast) and 906's. car ran great w/ 6psi of boost.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328593
05/26/09 10:05 AM
05/26/09 10:05 AM
If he has ~3 or 4 psi at the carb when it lays down the fuel delivery is good. describe the symptoms more, is it cutting out or just seems like it wont go any higher?. only in 3rd gear?
Re: 440 problem [Re: Mr.Yuck] #328594
05/26/09 10:08 AM
05/26/09 10:08 AM
Florida STAYcation
Florida STAYcation
He needs some big-time shaved closed-chambered IRON heads.
Re: 440 problem [Re: RapidRobert] #328595
05/26/09 10:10 AM
05/26/09 10:10 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
no he has to short shift 1st and 2nd. He says..."it just lays down" He has check and replaced, fuel system, electrical, valve springs and went w/ roller rockers. It has had the same issues each time. Could the heads be causing some flow problems in the chamber at 5500??? Even at 8.7:1 the thing should pull past 5500.
Coming soon!!!!
Re: 440 problem [Re: dOc !] #328596
05/26/09 10:12 AM
05/26/09 10:12 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I think he's going w/ a set of shaved 906's and a steel shim head gasket...if that doesn't fix it I think he's going to yank it and find a new short block.
Coming soon!!!!
Re: 440 problem [Re: Mr.Yuck] #328597
05/26/09 10:19 AM
05/26/09 10:19 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I wonder if it is a converter issue. The cam, converter, and gears all need to work together to reach full potential. Just a thought, take it as you will as I am only a parts changer.
Re: 440 problem [Re: moparmojo] #328598
05/26/09 11:42 AM
05/26/09 11:42 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The rocker ratio could be affecting the valvetrain stability with those agressive lobes. Is he running a 1.6 rocker ratio by chance ?
Dulcich did a series of tests a few years back using an agressive flat tappet hyd cam with a 1.6 rocker and the engine wouldn't RPM.
Dwayne @ PRH has observed the same thing during dyno testing....agressive flat tappet hyd cams and 1.6 rocker ratios nose over early ; usually several hundred rpm lower than with a 1.5 rocker.
Ron
