440 problem
#328579
05/25/09 08:14 PM
05/25/09 08:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
A friend of mine has a 440. It falls falt at 5500. Background, .030 over 9:1 ish (.070 in the hole pistons), OTB E-heads (84cc), Fel-Pro's, 513 VooDoo cam, TTi headers (and 2.5 X-pipe exhaust), RPM intake Demon carb. He has swaped boxes, coils, distribs, cap/rotor carbs, fuel lines, pumps, went w/ roller rockers, swaped valve springs, you name it. It just will not pull above 5500 and is laying down a ton at the top end. Could the E-heads be causing the problems? He has a set of nice 906's he might try. If you need more info it's a 69 RR 727, 175k convert and 3.55's. So far the best he can do is 13.0 @100mph falling off. He runs thru the pipes...could that be a problem?? Any ideas?
Re: 440 problem
[Re: goldmember]
#328585
05/25/09 09:31 PM
05/25/09 09:31 PM
Mr.Yuck
Brookeville, Md
If the tune is good,I'd look at a possible fuel delivery problem. Does the valvetrain make noise at say 5000 rpm? Although I've run lots of Harolds solid grinds I've seen and heard first hand that instability can be a problem with the Voodoo hyd cams. It could be basecircle runout or another cause,some work fine and others don't. You could install solid lifters as a test,I'd check for basecircle runout as well.It's not the heads causing the problem but details about the valvespring seat and open pressure is important.
yeah he's thinking about check w/ solid lifters. I should add hes a master mechanic and has build many many many BB and SB mopars and this is racking his brain.
Re: 440 problem
[Re: Mr.Yuck]
#328586
05/25/09 09:50 PM
05/25/09 09:50 PM
RapidRobert
recent problem or since built? He has a fuel psi gauge inside the car? Will it rev to the offending point(5500)in neutral?
Re: 440 problem
[Re: Mr.Yuck]
#328590
05/26/09 09:19 AM
05/26/09 09:19 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
E-heads and 9:1? He needs BOOST! That's the combo I'm running under my turbos. The Speed Pro 9:1 forged pistons measure out to 8.7:1 compression.
It's a decent setup. Just add PSI.
Re: 440 problem
[Re: RapidRobert]
#328591
05/26/09 09:42 AM
05/26/09 09:42 AM
Mr.Yuck
Brookeville, Md
7.5lbs of pressure.
I'd think that would be his idle reading & he IS showing several psi or more @5500 going down the strip when it acts up?
He's fine all the way down the track... I'm just wondering if something happening in the chamber causing some flow issues???
Re: 440 problem
[Re: feets]
#328592
05/26/09 09:43 AM
05/26/09 09:43 AM
Mr.Yuck
Brookeville, Md
That's what I keep telling him.. I ran the speed pro's (cast) and 906's. car ran great w/ 6psi of boost.
Re: 440 problem
[Re: Mr.Yuck]
#328593
05/26/09 10:05 AM
05/26/09 10:05 AM
RapidRobert
If he has ~3 or 4 psi at the carb when it lays down the fuel delivery is good. describe the symptoms more, is it cutting out or just seems like it wont go any higher?. only in 3rd gear?
Re: 440 problem
[Re: RapidRobert]
#328595
05/26/09 10:10 AM
05/26/09 10:10 AM
Mr.Yuck
Brookeville, Md
no he has to short shift 1st and 2nd. He says..."it just lays down" He has check and replaced, fuel system, electrical, valve springs and went w/ roller rockers. It has had the same issues each time. Could the heads be causing some flow problems in the chamber at 5500??? Even at 8.7:1 the thing should pull past 5500.
Re: 440 problem
[Re: dOc !]
#328596
05/26/09 10:12 AM
05/26/09 10:12 AM
Mr.Yuck
Brookeville, Md
He needs some big-time shaved closed-chambered IRON heads.
I think he's going w/ a set of shaved 906's and a steel shim head gasket...if that doesn't fix it I think he's going to yank it and find a new short block.
Re: 440 problem
[Re: moparmojo]
#328598
05/26/09 11:42 AM
05/26/09 11:42 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
The rocker ratio could be affecting the valvetrain stability with those agressive lobes. Is he running a 1.6 rocker ratio by chance ? Dulcich did a series of tests a few years back using an agressive flat tappet hyd cam with a 1.6 rocker and the engine wouldn't RPM. Dwayne @ PRH has observed the same thing during dyno testing....agressive flat tappet hyd cams and 1.6 rocker ratios nose over early ; usually several hundred rpm lower than with a 1.5 rocker. Ron
