Heater Motor Vent Tube: '68-'70 B-body non-a/c #327882
05/25/09 07:02 AM
05/25/09 07:02 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Anyone know of a source for the Heater Motor Vent Tube between the heater core body and the fan blower motor? Mine could use replacement. It's usable, but would prefer a better one....
Troy
Houston Mopar Connection Club
Re: fan blower cooling hose: '68-'70 B-body non-a/c [Re: hemi68charger] #327883
05/25/09 07:02 AM
05/25/09 07:02 AM
Houston, Tx
Houston, Tx
front
Troy
Re: fan blower cooling hose: '68-'70 B-body non-a/c [Re: hemi68charger] #327884
05/25/09 08:28 AM
05/25/09 08:28 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
R/T Specialties
Re: fan blower cooling hose: '68-'70 B-body non-a/c [Re: RoadRunnerJD] #327885
05/25/09 08:59 AM
05/25/09 08:59 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Yep. Tom is the one making those tubes.
NICE JOB on the heater box.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: hemi68charger] #327886
05/25/09 10:01 AM
05/25/09 10:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
this one ?
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: gtx6970] #327887
05/25/09 10:39 AM
05/25/09 10:39 AM
Houston, Tx
Houston, Tx
Bill, this is the original. Looks to have two formed bends in it... But, looks like the same...
Troy
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: hemi68charger] #327888
05/25/09 11:44 AM
05/25/09 11:44 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Troy,
the repop does have 2 distinct bends in it. But you may not be able to see it in the picture I have. If you prefer another view let me know I have a few of them here
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: gtx6970] #327889
05/25/09 12:17 PM
05/25/09 12:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
The problem I had was finding a blower motor with the hole in the correct spot.. Anyone reproing the correct blower motor??
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: gtx6970] #327890
05/25/09 12:59 PM
05/25/09 12:59 PM
Houston, Tx
Houston, Tx
Troy,
Bill,
That's not necessary, I trust ya. I may place an order here soon from ya...
Troy
Troy
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: hemi68charger] #327891
05/25/09 01:50 PM
05/25/09 01:50 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
If Bills' doesn't work out I have very nice used ones as well as a few rebuilt motors left.
Jules
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: minivan] #327892
05/25/09 02:06 PM
05/25/09 02:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats why I bought an NOS one off Ebay about seven years ago...
The other issue I had was all the afternarket heater cores have slightly shorter water supply tubes so ewhen you bolt the heater box up to the firewall the tubes only stick throught about .5" you could make it work but it's marginal at best... I looked for an NOS heater core with no lucky, considered having my original recored but instead I cut about 3" of the orignal tubes off an old core, swaged them open slightly so they would slide over standard 5/8 tubing than cut 1.5" off my new core, next I had the guy at the radiator shop solder the extensions onto my new core... Now about 1.25" extend out of the firewall...
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: 1_WILD_RT] #327893
05/26/09 08:46 AM
05/26/09 08:46 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I wish I had known about this little trick a year ago... I rebuilt my heater box and used a heater core from the auto parts store. I "assumed" everything would be the same fit. I was still able to get the hoses on but it was a real pain to get those spring clamps on with it being so close to the firewall. I would test fit what you have then make the call. Next time my heater box has to come out I will definitely extend those pipes.
68 Hemi Road Runner
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: 68jim] #327894
05/26/09 09:57 AM
05/26/09 09:57 AM
Houston, Tx
Houston, Tx
This is insightful. Instead of welding, I may just "shim" the new heater core radiator outward by making "extensions" for the four attach points. There's enough room within the cavity of the box to allow the complete unit to be shifted back without any problems that I can think of. I would hate to have a weld break on my later on.... guess it's time for experimentation.
Now I want to take the new one out again and compare the two.
Troy
Troy
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: hemi68charger] #327895
05/26/09 11:59 AM
05/26/09 11:59 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
How did you paint the yellow numbers on the front cover?? I am getting ready to rebuild mine, and haven't figured that part out yet. Thanks.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: Prodart440] #327896
05/26/09 12:17 PM
05/26/09 12:17 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Rubber stamp and ink.
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: 68jim] #327897
05/26/09 12:20 PM
05/26/09 12:20 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Sorry Troy...I saw the question and posted the picture and response without realizing that I did not post the original picture...my bad...
Here was the shot I thought was up there. And go figure that one was taken before the stamp...
68 Hemi Road Runner
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: 68jim] #327898
05/26/09 01:02 PM
05/26/09 01:02 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
So, could I rent that from you??
Aaron
68 Coronet 440
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: Prodart440] #327899
05/26/09 03:03 PM
05/26/09 03:03 PM
Houston, Tx
Houston, Tx
Aaron..
I can send you a document I have that someone passed down to me. I'd like to return the mopar-favor. If you have a stamp business any where near you, you can probably get it made for yourself for about $15. The yellow paint I got from Hobby Lobbym straight up yellow or the closest I came to with my original.
Troy
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: 68jim] #327900
05/26/09 03:04 PM
05/26/09 03:04 PM
Houston, Tx
Houston, Tx
68 Hemi Road Runner
Jim, oh no, you addressed the original question I had about the vent tube. Thanks.. Your box looks great !!! I learned a lot during this process and hope it'll carry over to my next project.
Troy
Troy
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c [Re: Prodart440] #327901
05/26/09 07:35 PM
05/26/09 07:35 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Aaron, I gave my stamp and ink to the guy who painted my car since he needed it for his 68 GTX. If you, or anyone else, are still interested send me a PM and I will give you his email/phone #. The ink bottle will probably do a 1000 stamps... I'm pretty sure he can either send you the stamp or you can send him your plate. Good Luck!
