Heater Motor Vent Tube: '68-'70 B-body non-a/c
#327882
05/25/09 07:02 AM
05/25/09 07:02 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Anyone know of a source for the Heater Motor Vent Tube between the heater core body and the fan blower motor? Mine could use replacement. It's usable, but would prefer a better one....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Heater Motor Vent Tube: '68-'70 B-body non-a/c
[Re: gtx6970]
#327887
05/25/09 10:39 AM
05/25/09 10:39 AM
hemi68charger
Houston, Tx
Bill, this is the original. Looks to have two formed bends in it... But, looks like the same...
[Re: gtx6970]
#327890
05/25/09 12:59 PM
05/25/09 12:59 PM
hemi68charger
Houston, Tx
Troy, the repop does have 2 distinct bends in it. But you may not be able to see it in the picture I have. If you prefer another view let me know I have a few of them here
Bill, That's not necessary, I trust ya. I may place an order here soon from ya...
Troy
[Re: minivan]
#327892
05/25/09 02:06 PM
05/25/09 02:06 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The problem I had was finding a blower motor with the hole in the correct spot.. Anyone reproing the correct blower motor??
Thats why I bought an NOS one off Ebay about seven years ago...
The other issue I had was all the afternarket heater cores have slightly shorter water supply tubes so ewhen you bolt the heater box up to the firewall the tubes only stick throught about .5" you could make it work but it's marginal at best... I looked for an NOS heater core with no lucky, considered having my original recored but instead I cut about 3" of the orignal tubes off an old core, swaged them open slightly so they would slide over standard 5/8 tubing than cut 1.5" off my new core, next I had the guy at the radiator shop solder the extensions onto my new core... Now about 1.25" extend out of the firewall...
[Re: 1_WILD_RT]
#327893
05/26/09 08:46 AM
05/26/09 08:46 AM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
I wish I had known about this little trick a year ago... I rebuilt my heater box and used a heater core from the auto parts store. I "assumed" everything would be the same fit. I was still able to get the hoses on but it was a real pain to get those spring clamps on with it being so close to the firewall. I would test fit what you have then make the call. Next time my heater box has to come out I will definitely extend those pipes.
Jim 68 Hemi Road Runner
[Re: 68jim]
#327894
05/26/09 09:57 AM
05/26/09 09:57 AM
hemi68charger
Houston, Tx
This is insightful. Instead of welding, I may just "shim" the new heater core radiator outward by making "extensions" for the four attach points. There's enough room within the cavity of the box to allow the complete unit to be shifted back without any problems that I can think of. I would hate to have a weld break on my later on.... guess it's time for experimentation. Now I want to take the new one out again and compare the two. Troy
[Re: hemi68charger]
#327895
05/26/09 11:59 AM
05/26/09 11:59 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
How did you paint the yellow numbers on the front cover?? I am getting ready to rebuild mine, and haven't figured that part out yet. Thanks.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#327899
05/26/09 03:03 PM
05/26/09 03:03 PM
hemi68charger
Houston, Tx
Rubber stamp and ink.
So, could I rent that from you??
Aaron.. I can send you a document I have that someone passed down to me. I'd like to return the mopar-favor. If you have a stamp business any where near you, you can probably get it made for yourself for about $15. The yellow paint I got from Hobby Lobbym straight up yellow or the closest I came to with my original.
[Re: 68jim]
#327900
05/26/09 03:04 PM
05/26/09 03:04 PM
hemi68charger
Houston, Tx
Sorry Troy...I saw the question and posted the picture and response without realizing that I did not post the original picture...my bad...
Here was the shot I thought was up there. And go figure that one was taken before the stamp...
Jim, oh no, you addressed the original question I had about the vent tube. Thanks.. Your box looks great !!! I learned a lot during this process and hope it'll carry over to my next project.
Troy
[Re: Prodart440]
#327901
05/26/09 07:35 PM
05/26/09 07:35 PM
68jim
Southeast Virginia
Aaron, I gave my stamp and ink to the guy who painted my car since he needed it for his 68 GTX. If you, or anyone else, are still interested send me a PM and I will give you his email/phone #. The ink bottle will probably do a 1000 stamps... I'm pretty sure he can either send you the stamp or you can send him your plate. Good Luck!
