B1 Head Flow Numbers / Potential #327441
05/24/09 08:01 PM
05/24/09 08:01 PM
U.S.
moparniac Offline OP
U.S.
What does a fully set fo B1 originals flow... how much HP can I get out of them on pump gas 11.5 to compression.... mid 260's solid roller
Do they require special rockers / special headers and intake? is 500 cubes enough for the heads...
thx
thinking about next years setup already and want to plan ahead..
Mopar Performance
Re: B1 Head Flow Numbers / Potential [Re: moparniac] #327442
05/24/09 08:36 PM
05/24/09 08:36 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'm not an expert, but have done some research for a friends engine.
They use their own specific rocker
They require a specific piston as the Valve position is different to standard BB Mopar.
B1 originals will over 400cfm when ported properly
Specific Header flanges and Intake has to be used. For RB block Intake Spacers are required
AL...
Alan Jones
Re: B1 Head Flow Numbers / Potential [Re: LA360] #327443
05/24/09 08:42 PM
05/24/09 08:42 PM
SoCal
Brian Hafliger Offline
SoCal
Here's a link to a post I did last year.
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Brian
IMM Engine & Dyno
Brian Hafliger
Re: B1 Head Flow Numbers / Potential [Re: Brian Hafliger] #327444
05/24/09 09:33 PM
05/24/09 09:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Diff pistons,diff rockers,diff headers, diff intake, diff pushrods. You would be better off building a new motor from the get go for B1 Stuff..
Dont you want to try to maximize your current combo first? The secret to going fast isnt just throwing new parts at it, you probably know this by now..
Re: B1 Head Flow Numbers / Potential [Re: moparniac] #327445
05/24/09 10:19 PM
05/24/09 10:19 PM
gregsdart Offline
gregsdart  Offline
If you have a well built shortblock, you can get very close to B1 performance with a set of fully ported 440-1 heads, and need only change the valve notchs (maybe need them larger) rather than change pistons. Headers would also be more likely to fit.
Re: B1 Head Flow Numbers / Potential [Re: Brian Hafliger] #327446
05/24/09 10:26 PM
05/24/09 10:26 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
Brian
IMM Engine & Dyno
That is nice work Brian. Steve
Engine by DeTar http://www.kansasbadman.com
Re: B1 Head Flow Numbers / Potential [Re: moparniac] #327447
05/24/09 10:53 PM
05/24/09 10:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
thx
My B1 originals ported by Koffels flow around 440 CFM on the intake side I know of one motor that is in a members car that has a set of ported B1 that made over one thousand HP on race gas I beleive that motor was a 525 C.I. or close to that It was a all out race motor intended for heads up racing in the PSCA series on the west coast. Lower compression and a smaller cam like your talking about should make close to 850 hp on pump gas with a single 1050 Dominator tuned properly All the components you ask about are B1 specific, you need the complete top end package and special exhaust flanges for custom made headers that Big Dad sells As well as the proper pistons with deep enough valve reliefs to clear your cam lift at TDC
Re: B1 Head Flow Numbers / Potential [Re: Cab_Burge] #327448
05/25/09 08:53 AM
05/25/09 08:53 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
B1s are somewhat exotic..they take all the special parts that have been mentioned. The B1-PSO head is for die hard wedge racers. By far the best wedge head available, they flow over 470+ cfm but are costly $$$$.. The B1-MC is next best and only a little more $$ than the original B1.They will flow around 450 CFM.
Re: B1 Head Flow Numbers / Potential [Re: B1Fish540] #327449
05/25/09 11:28 AM
05/25/09 11:28 AM
U.S.
U.S.
I will optimize this combo for this season and maybe sell the whole motor is the way I was thinking........
I cant decide whether to sell my roller or keep it since Ive done so much work to it and go light like a badd dart or demon.... or go all in on a awesome big inch street wedge
thoughts.....
Mopar Performance
Re: B1 Head Flow Numbers / Potential [Re: Brian Hafliger] #327450
05/25/09 11:37 AM
05/25/09 11:37 AM
Inland Empire
Sci Fi 64 Offline
Sci Fi 64  Offline
Inland Empire
These heads and all related parts are for sale in the parts section right now. Employment issues have forced me in another direction. They are still brand new and have never been used. Beautiful work on these heads Brian. Thanks.
Re: B1 Head Flow Numbers / Potential [Re: Sci Fi 64] #327451
05/25/09 12:02 PM
05/25/09 12:02 PM
U.S.
U.S.
so with the right made piston can you get them to have 11.5 to 1 compression at 74.5 cc.....
Mopar Performance
Re: B1 Head Flow Numbers / Potential [Re: moparniac] #327452
05/25/09 02:09 PM
05/25/09 02:09 PM
SoCal
SoCal
Ofcourse!
Brian Hafliger
Re: B1 Head Flow Numbers / Potential [Re: moparniac] #327453
05/26/09 06:30 PM
05/26/09 06:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
thoughts.....
Yep...
Re: B1 Head Flow Numbers / Potential [Re: Brian Hafliger] #327454
05/26/09 09:51 PM
05/26/09 09:51 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
Brian
IMM Engine & Dyno
Simply fabulous post right there Makes one start thinking & that usually costs me alot of money when that happens
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
