Re: What spark plugs for Edel Heads small block?
[Re: LAR_414]
#324492
05/21/09 08:49 AM
05/21/09 08:49 AM
After fouling problems with NGKs some one suggested I try these: Champion RC12LYC (412) No more fouling problems. May be a little hot, but no more fouling.Weird looking plug, real long nose. Work perfectly. Been using the same plugs for a couple of years.
#324493
05/21/09 10:11 AM
05/21/09 10:11 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
[Re: 69Cuda340S]
#324495
05/21/09 02:43 PM
05/21/09 02:43 PM
Autolite 3924's or ar 3924's..i wouldn't put champions in my lawn mower..
[Re: mcat4321]
#324497
05/21/09 03:07 PM
05/21/09 03:07 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am running NGK R5672A-8 stock # 7173 but I do plan on trying some Autolite 3911
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#324498
05/21/09 03:11 PM
05/21/09 03:11 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
I have champions in my lawn mower, leaf blower and weed wacker. I also have them in my car. they work great in all of them. I have had the same plugs in the lawn equipment for 8 years.
what problems have you had that we should know about?
[Re: Joshs68]
#324499
05/21/09 03:20 PM
05/21/09 03:20 PM
Triple Threat
Renton Washington
I don't recall, I put them in the heads when I put them on 2 years ago, 3-4 thousand miles later and 300 or so passes, they're still in the car.
[Re: Joshs68]
#324500
05/21/09 03:21 PM
05/21/09 03:21 PM
[Re: Joshs68]
#324501
05/21/09 04:30 PM
05/21/09 04:30 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
I used to run Champions in my 340 back in the '80s and they had so much resistance the spark would arc out of the plug boot and to the head. Spent a long time swapping in new plugs, new wires, new everything. As soon as I stopped using Champions and went to Autolites problem went away. I will NEVER use Champion junk again.
[Re: LAR_414]
#324507
05/22/09 08:17 AM
05/22/09 08:17 AM
Posts: 1,178 Indy
FlyFish
Indy
I use NGK R5671A-8, stock #4554. For NGK plugs the higher the number at the end, the colder the plug (-7 is hotter than -10). For a street car, I would try a -7 or -8…I have had issues with fouling -8’s when my car was a little rich, but they worked well on the bottle. I used -7's for everyday driving.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
#324508
05/22/09 08:47 AM
05/22/09 08:47 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I asked the same question a few weeks ago, here is a link to that discussion, I went with AR3911. For one they are what I run in my BB car and Ryan J recommended them to others: https://board.moparts.org/ubbthreads/show...rue#Post5171990
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
