46RH/A518 converter #3230376
05/01/24 12:00 AM
05/01/24 12:00 AM
Canada
WO23Coronet Offline OP
Canada
Hey there. Wondering if a 727 converter will work in an A518? I have one in my 90 Ram D150 that I'm Hemi swapping. It's a non lock up A518. Will have 4.56 gears, 30" tall tires, basically stock pre Eagle 5.7 with a 6.1 cam, SRT exhaust manifolds, maybe ported heads, should make peak power around 6200-6500 rpm. Should weigh 4200lbs or so with me in it. Have a chance to buy a PTC 10" 3500 stall for a 727. If it will work I think it would be a decent converter.
Re: 46RH/A518 converter [Re: WO23Coronet] #3230389
05/01/24 05:44 AM
05/01/24 05:44 AM
A727Tflite Offline
A727Tflite  Offline
It will work.
Re: 46RH/A518 converter [Re: A727Tflite] #3230430
05/01/24 09:53 AM
05/01/24 09:53 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Also agree - I use a 727 converter in the A-518 that I swapped into my Cuda.
Re: 46RH/A518 converter [Re: mrob] #3230524
05/01/24 06:05 PM
05/01/24 06:05 PM
Indiana
P
Pentastar440 Offline
P
Indiana
A 727 Converter will work on any 2-wire (Non Lockup) A-518 transmission
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 46RH/A518 converter [Re: Pentastar440] #3230525
05/01/24 06:19 PM
05/01/24 06:19 PM
A727Tflite Offline
A727Tflite  Offline
Actually it will work on on any RE/RH if you make it a non-lockup.
Re: 46RH/A518 converter [Re: A727Tflite] #3230552
05/01/24 09:06 PM
05/01/24 09:06 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
How does one do that?
I mean the obvious part is the input shaft, and most likely part of the valve body...but any other internals???
Re: 46RH/A518 converter [Re: Diplomat360] #3230554
05/01/24 09:21 PM
05/01/24 09:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Input shaft , corresponding stator support I assume , make sure the interface between the input shaft , thrust washer and mainshaft works. Possibly the valvebody but since lockup is electrically applied making sure it can't happen might be enough since if you are doing it to an RE you need the electronic govenor there and working ... unless you go full manual shifting ?
Re: 46RH/A518 converter [Re: Diplomat360] #3230570
05/01/24 11:50 PM
05/01/24 11:50 PM
A727Tflite Offline
A727Tflite  Offline
Input shaft and stator support. That’s all you “have to” replace.
