Re: Engine-trans crank centerline in car
[Re: cudaman1969]
#3230098
04/29/24 11:10 PM
04/29/24 11:10 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The driveline CL is parallel to the chassis CL, front of crank to rear u joint, or should be, and is offset to the right 1 3/16' or 1 1/4" depending on who you ask.
[Re: CMcAllister]
#3230109
04/30/24 12:05 AM
04/30/24 12:05 AM
Posts: 31,050 Oregon
AndyF
The offset depends on the body platform. Early A body is different than later A body. Later A body is 1.25 offset so pinion needs be offset 1.25 also. Race car guys usually put a Ford 9 inch in the center of the car since it looks better and the offset is almost right for a Mopar. I can't remember on a Dana 60 if the housing ends up in the center or not. It is close.
[Re: AndyF]
#3230170
04/30/24 10:34 AM
04/30/24 10:34 AM
Posts: 10,032 MN
JERICOGTX
MN
I can't remember on a Dana 60 if the housing ends up in the center or not. It is close. It is not centered with a Dana 60.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3230276
04/30/24 04:24 PM
04/30/24 04:24 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I can't remember on a Dana 60 if the housing ends up in the center or not. It is close. It is not centered with a Dana 60. The passenger side axles are a bunch shorter than the drivers side axles on all stock Mopar Dana 60 applications regardless of year or body style Dang them Mopar engineers anyways
[Re: cudaman1969]
#3230284
04/30/24 04:49 PM
04/30/24 04:49 PM
Cab_Burge
[Re: Cab_Burge]
#3230345
04/30/24 08:58 PM
04/30/24 08:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stock floors and driveshaft tunnel, you aren't going to get the engine/driveline in the center.
[Re: CMcAllister]
#3230455
05/01/24 11:58 AM
05/01/24 11:58 AM
Posts: 2,513 PA
moparacer
PA
My old junker has 1 inch of offset to the right. Has/had stock floor and driveshaft tunnel.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
