Engine-trans crank centerline in car #3230095
04/29/24 11:04 PM
04/29/24 11:04 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
On an a-body 340 engine, without installing the engine and trans (next month maybe) I need to know if that centerline follows inline with say the rocker panels? Is this shown in the service manual? I’m trying to set the pinion angle on the Dana with CT split monos. Or just weld perch’s the same as stock (5* up). Springs are stock ride height. I want pinion same degree as crank under power.
Re: Engine-trans crank centerline in car [Re: cudaman1969] #3230098
04/29/24 11:10 PM
04/29/24 11:10 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
The driveline CL is parallel to the chassis CL, front of crank to rear u joint, or should be, and is offset to the right 1 3/16' or 1 1/4" depending on who you ask.
Re: Engine-trans crank centerline in car [Re: CMcAllister] #3230109
04/30/24 12:05 AM
04/30/24 12:05 AM
AndyF Online content
AndyF  Online Content
The offset depends on the body platform. Early A body is different than later A body. Later A body is 1.25 offset so pinion needs be offset 1.25 also. Race car guys usually put a Ford 9 inch in the center of the car since it looks better and the offset is almost right for a Mopar. I can't remember on a Dana 60 if the housing ends up in the center or not. It is close.
Re: Engine-trans crank centerline in car [Re: AndyF] #3230170
04/30/24 10:34 AM
04/30/24 10:34 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
It is not centered with a Dana 60.
69 GTX 68 Road Runner
Re: Engine-trans crank centerline in car [Re: JERICOGTX] #3230185
04/30/24 11:16 AM
04/30/24 11:16 AM
fredericksburg,va
fredericksburg,va
Ok I’ll lay level on rocker to level car then check angle on rear, thanks
Re: Engine-trans crank centerline in car [Re: JERICOGTX] #3230276
04/30/24 04:24 PM
04/30/24 04:24 PM
iagree scope
The passenger side axles are a bunch shorter than the drivers side axles on all stock Mopar Dana 60 applications regardless of year or body style scope Dang them Mopar engineers anyways grin whistling
Re: Engine-trans crank centerline in car [Re: cudaman1969] #3230284
04/30/24 04:49 PM
04/30/24 04:49 PM
Moving the motor over to the passenger side of the car helps traction on that side also work up
More traction is way better than a tiny bit too little, huh grin
Mopar engineers move the motors over to the passenger side to give the drivers more foot room work up
Re: Engine-trans crank centerline in car [Re: Cab_Burge] #3230345
04/30/24 08:58 PM
04/30/24 08:58 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stock floors and driveshaft tunnel, you aren't going to get the engine/driveline in the center.
Re: Engine-trans crank centerline in car [Re: CMcAllister] #3230455
05/01/24 11:58 AM
05/01/24 11:58 AM
PA
moparacer Offline
moparacer  Offline
PA
My old junker has 1 inch of offset to the right. Has/had stock floor and driveshaft tunnel.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Engine-trans crank centerline in car [Re: moparacer] #3230502
05/01/24 03:12 PM
05/01/24 03:12 PM
Offset varies depending on the year, make and model.
