On an a-body 340 engine, without installing the engine and trans (next month maybe) I need to know if that centerline follows inline with say the rocker panels? Is this shown in the service manual? I’m trying to set the pinion angle on the Dana with CT split monos. Or just weld perch’s the same as stock (5* up). Springs are stock ride height. I want pinion same degree as crank under power.
