TTI exhaust muffler choice? #3228027
04/19/24 09:57 AM
04/19/24 09:57 AM
PA
maxwedge1 Offline OP
PA
after 20 yrs the 3" dynomax super turbos are shot....i would like something a bit more aggressive.
is there anything else the same dimensions that plugs in or close enough that would work with some slip extensions or will a trip to exhaust shop be needed?
Re: TTI exhaust muffler choice? [Re: maxwedge1] #3228034
04/19/24 10:49 AM
04/19/24 10:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
dynomax ultra flos , what length are your current cases ?
Re: TTI exhaust muffler choice? [Re: JohnRR] #3228051
04/19/24 11:20 AM
04/19/24 11:20 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I like Pypes race pros’ I picked up 2/10’s changing to them from the muffler you have been running. Also lost the drone that it had at 2500 rpm. Do not get the violators, they are loud and sound horrible.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: TTI exhaust muffler choice? [Re: JohnRR] #3228073
04/19/24 12:22 PM
04/19/24 12:22 PM
PA
PA
case is 16 " overall is 23. i have looked around and found some close but no way of knowing if the pipe centerlines will match
Re: TTI exhaust muffler choice? [Re: maxwedge1] #3228096
04/19/24 01:39 PM
04/19/24 01:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Within a given case size, I haven't found the entry/exit pipe centerlines to be significantly different if they're the same center/offset design.
It can get tricky if you have to rotate a tailpipe a bit in a tight space and/or welded-on tips on an A-body.
I swapped 3 sets of mufflers on a '64 B-body trying to get the right sound, and it was easy.
Of my 2 Road Runners, the yellow one with a full restoration exhaust from Accurate is louder and crisper than the other (blue car) which is the same except for Dynomax Super Turbos.
Engine-wise, yellow has a bit more CR and slightly more aggressive cam specs, and the Decor Group chrome tips; both have stock exhaust manifolds.
Re: TTI exhaust muffler choice? [Re: topside] #3228115
04/19/24 03:58 PM
04/19/24 03:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hooker Aero Chambers sound good, supposedly flow pretty well, and are not crazy loud under normal driving. Unsure if they are an easy transfer from what you have?
If super aggressive sounding is the priority I think of the Spintech mufflers. More like a Flowmaster type sound on steroids than an insulated turbo muffler.
Re: TTI exhaust muffler choice? [Re: FurryStump] #3228354
04/20/24 11:15 PM
04/20/24 11:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Short case ?
Re: TTI exhaust muffler choice? [Re: JohnRR] #3228376
04/21/24 08:44 AM
04/21/24 08:44 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
It fit in place of the Dynomax muffler with the TTI system that is in my 68 Barracuda Fastback
Re: TTI exhaust muffler choice? [Re: FurryStump] #3228377
04/21/24 08:48 AM
04/21/24 08:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks ... that would be the shortcase .
Re: TTI exhaust muffler choice? [Re: FurryStump] #3228742
04/23/24 11:33 AM
04/23/24 11:33 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
x2
Re: TTI exhaust muffler choice? [Re: maxwedge1] #3229171
04/25/24 05:13 PM
04/25/24 05:13 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
FWIW, I believe the Dynomax mufflers have a 16" body length. The Mopar mufflers are offset in / center out.
Re: TTI exhaust muffler choice? [Re: Sunroofcuda] #3229187
04/25/24 06:10 PM
04/25/24 06:10 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
1966 Satellite 383 , full 2.5inch TTI exhaust with Dynomax Super turbos
https://www.youtube.com/watch?v=H1eP_QMFfMU
Re: TTI exhaust muffler choice? [Re: gtx6970] #3229188
04/25/24 06:12 PM
04/25/24 06:12 PM
It's a dry heat
It's a dry heat
1966 Satellite Hemi , slight bump over stock compression. Stock H pipe and 2.25 inch tail pipes
Also Dynomax Super Turbos
https://www.youtube.com/watch?v=gg7SvUNjtGA
Both are exact same style mufflers, just different part number due to pipe size
