vacuum Catch can location. #3223644
03/30/24 08:22 AM
03/30/24 08:22 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Were do you mount yours? Looking for a better location on my turbo setup.
Re: vacuum Catch can location. [Re: racerx] #3223665
03/30/24 09:59 AM
03/30/24 09:59 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have mine mounted to my front plate.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: vacuum Catch can location. [Re: 6PKRTSE] #3223699
03/30/24 12:31 PM
03/30/24 12:31 PM
Me too, right next to the pump up
Re: vacuum Catch can location. [Re: Cab_Burge] #3223715
03/30/24 01:57 PM
03/30/24 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have mounted them on the motorplate, the side of the radiator, core support and downtubes or strut bars. Just depends on what type of chassis. The downfall of a chassis car is sometimes room especially up front gets really tight. Some random examples of some of my stuff.
Re: vacuum Catch can location. [Re: racerx] #3224170
04/01/24 09:54 AM
04/01/24 09:54 AM
an8sec70cuda Offline
Passenger's side of the motorplate. Vacuum pump is on the driver's side.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: vacuum Catch can location. [Re: an8sec70cuda] #3224206
04/01/24 11:44 AM
04/01/24 11:44 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same as mine pulling from one valve cover. Anyone see any additional vacuum increase by putting a Tee fitting within the line to pull from both sides from both valve covers?
Re: vacuum Catch can location. [Re: racerx] #3224357
04/01/24 07:01 PM
04/01/24 07:01 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
The catch can location that everyone is showing, what's the trick to keeping that filter from oiling up? This is my reasoning for asking this question.
I thought about just moving it to the rear like catch cans for trans.
Re: vacuum Catch can location. [Re: 6PKRTSE] #3224377
04/01/24 08:38 PM
04/01/24 08:38 PM
The windage starts around the crankshaft and rises,, I don't think you need to have it suck from both sides twocents work up
Re: vacuum Catch can location. [Re: racerx] #3224390
04/01/24 10:11 PM
04/01/24 10:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run this Moroso 22635 fitting. It helps from sucking oil.
Re: vacuum Catch can location. [Re: racerx] #3224565
04/02/24 05:17 PM
04/02/24 05:17 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Every time I had an engine that is pulling oil (minus putting it in the lifter valley), the way to stop it was to seal the engine up. Without air or blowby, oil can't be pulled into the vacuum pump. I had engines with huge vacuum leak that pulled 3 or 4 oz per dyno pull, at that point we stop and find the source of the leak.
Joe
Without Data, you’re just another guy with an opinion.
Re: vacuum Catch can location. [Re: 6PKRTSE] #3224627
04/03/24 07:18 AM
04/03/24 07:18 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Those are the fitting that i run shruggy
Re: vacuum Catch can location. [Re: sr4440] #3224655
04/03/24 07:50 AM
04/03/24 07:50 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Joe
Agreed, I've also seen vacuum regulators fitted to valve covers tsk
Re: vacuum Catch can location. [Re: sr4440] #3224680
04/03/24 10:03 AM
04/03/24 10:03 AM
PA
moparacer Offline
moparacer  Offline
PA
Joe
iagree
Leaks cause too much air to move through the engine and that makes it pull a lot of oil.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: vacuum Catch can location. [Re: sr4440] #3224692
04/03/24 11:04 AM
04/03/24 11:04 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Joe
Exactly....
Re: vacuum Catch can location. [Re: Al_Alguire] #3225153
04/05/24 06:18 AM
04/05/24 06:18 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
How are you all baffling your valve covers to slow up the oil suction?
Re: vacuum Catch can location. [Re: racerx] #3225155
04/05/24 06:29 AM
04/05/24 06:29 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
I have two engines with a vac pump, neither of the valve covers has a baffle for the vac line. The amount of oil drawn through is negligible, I get more water in the catch can than oil and it isn't a lot. If I do start to get oil in the can I check for a leak, rocker cover gaskets, loose fittings etc. As has been stated, if the engine is sealed well and the vac relief valve (if used) is in the correct position you should draw very little oil.
Re: vacuum Catch can location. [Re: Tig] #3225158
04/05/24 07:28 AM
04/05/24 07:28 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Actually it's more moister than oil(e-85 fuel)I'm running a Moroso catch can with the baffle at the top. Most cars i see at the track has some sort of rag that's rap around the filter area to catch the excess oil.
I was looking at Motion works catch cans and they clam to not have this problem.
Re: vacuum Catch can location. [Re: racerx] #3225161
04/05/24 07:42 AM
04/05/24 07:42 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Yeah, I've seen that sweatband thing too and I will get a witness film around that area where it is in the car. The vac pump does draw condensation from the motor but once warm it's gone maybe a couple of minutes or more on a colder day. The actual catch can has a baffle in it and a drain petcock, it's about 90% water when I drain it. I'm guessing it takes longer to warm an engine up on E85 ?
Re: vacuum Catch can location. [Re: Tig] #3225194
04/05/24 11:06 AM
04/05/24 11:06 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I drain my catch can after every pass out of habit almost never even get a drop or two. I also drain it whenever I think about it after hundreds of street miles just to double check. Almost never get anything out of it then either. I run a vacuum sensor through the Racepak also so I always know vacuum is still good.
I do the same with draining my rad overflow as well. I usually get a little more from this if hotter temps outside.
