MPG #3217482
03/02/24 02:09 PM
03/02/24 02:09 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Any guesses as to what I'm getting for gas mileage? Stock 1970 440- 4 bbl. w/ 4.10's in a Dana. The dash does not have a trip odometer. Filling the tank and doing basic calculations isn't too accurate. TIA.
Re: MPG [Re: Kudakidd] #3217498
03/02/24 03:05 PM
03/02/24 03:05 PM
On the road cruising on light throttle pressures at or below 2500 RPM between 12.0 t0 15.0 MPG, around town depending on how your driving 6 to 10 MPG
Re: MPG [Re: Cab_Burge] #3217502
03/02/24 03:16 PM
03/02/24 03:16 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
10 mpg
Re: MPG [Re: d-150] #3217512
03/02/24 04:33 PM
03/02/24 04:33 PM
Kudakidd Offline OP
Kudakidd  Offline OP
As an addendum I'm taching 3,000rpm at 60 mph. I'd be thrilled with any mileage in the double digits! And I drive it like I had an egg under the go pedal. (Not all the time though. It is a Mopar!)
Re: MPG [Re: Kudakidd] #3217535
03/02/24 06:15 PM
03/02/24 06:15 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Without knowing how far you've gone, it's only guessing.
I think the worst I ever got was my Hemi RR 4-speed, 4.10s - with its healthy engine, and not caring about MPG, it'd get 8 MPG mostly.
At a steady RPM & light throttle on the highway, maintaining 3000 RPM, it could tickle 10-11 MPG overall.
I could never keep my leg out of it for long...
Re: MPG [Re: Kudakidd] #3217539
03/02/24 06:22 PM
03/02/24 06:22 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
It is a hot rod, I don't care what millage it gets. whistling LOL
My 440, fuel injected 6 Pac, 4:10 and Passion 4sp overdrive gets 11.2 mpg if I drive her gingerly. Real world every day driving is less than 10 mpg.
My Monster are real!
Living within your means makes life pretty easy.
Re: MPG [Re: Kudakidd] #3217545
03/02/24 07:08 PM
03/02/24 07:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's a heck of a lot more accurate than any guess you'll get here.
Why do you think it's not accurate?
Re: MPG [Re: topside] #3217574
03/02/24 08:57 PM
03/02/24 08:57 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Imagine if you had yer foot into it! lol
Re: MPG [Re: Kudakidd] #3217577
03/02/24 09:01 PM
03/02/24 09:01 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Some good real world info here. I was leaning toward about 8 mpg. I'm only saying that because the gas needle moves like a clock's second hand!
Anyone come across magazine specs?
Re: MPG [Re: Kudakidd] #3217590
03/02/24 10:30 PM
03/02/24 10:30 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Back in the early 70s fuel mileage wasn't a big issue, but horse power ratings where.
Someone may have an old add or dealer ProMo that listed MPGs.
Re: MPG [Re: Kudakidd] #3217593
03/02/24 10:44 PM
03/02/24 10:44 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Matters if you take long trips.
Otherwise, for the weekend occasional day trip/ride shouldn't matter.
Re: MPG [Re: Kudakidd] #3217669
03/03/24 10:33 AM
03/03/24 10:33 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Put a vacuum gauge in it. If it shows double digits at cruise, it should be dd mpg.
Hook up your vacuum advance. Anything that will increase cruise vacuum helps MPG.
Kevin
Re: MPG [Re: Twostick] #3217694
03/03/24 12:13 PM
03/03/24 12:13 PM
moparx Offline
moparx  Offline
smiles per gallon is what you should be concerned about, not miles per gallon. biggrin
seriously, having the vacuum advance hooked up and tuned for your combination [use the set screw inside the hose nipple to adjust tip in and make sure the advance can doesn't over advance] will make a big difference at steady cruise.
beer
Re: MPG [Re: PhillyRag] #3217787
03/03/24 05:12 PM
03/03/24 05:12 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Are you planning on taking the car on a long trip in the near future?
Is that why you want to get an MPG estimate?
Plymouth Makes It!
Re: MPG [Re: RoadRunnerLuva] #3217838
03/03/24 08:44 PM
03/03/24 08:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The trip odometer quit working on my truck about mid summer last year. Does you car still have a functioning odometer? Record the miles when you fill up, record the miles when you fill up the next time, and subtract the little number from the big number. Then divide that by the amount of gas you have added since the last fill up. the only way that is not accurate is if you didn't stop filling it at the same point each time. If you don't add any gas after the automatic shut off on the pump shuts off (buy the gas from the same pump from the same direction, at the same angle), you will be very close to getting the same fill each time.
I keep a little note book and a pen in the glove box to record the miles from the fast fill up. I can tell you pretty close how much gas its going to take to fill my truck up each time, based on the miles, and if it was all city, 1/2 city, or all highway driven. Any big block Mopar I ever had was between 8 mpg and 12mpg (that 12 was all highway).
Re: MPG [Re: RoadRunnerLuva] #3217848
03/03/24 09:08 PM
03/03/24 09:08 PM
Kudakidd Offline OP
Kudakidd  Offline OP
My idea of a long trip now is about 80 miles round trip.
Re: MPG [Re: Kudakidd] #3217922
03/04/24 08:08 AM
03/04/24 08:08 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
9.79 mpg
Re: MPG [Re: jcc] #3217929
03/04/24 08:44 AM
03/04/24 08:44 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Originally Posted by jcc
9.79 mpg
That may be spot on! lol
Re: MPG [Re: Kudakidd] #3218109
03/04/24 07:13 PM
03/04/24 07:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
8
Re: MPG [Re: lewtot184] #3218333
03/05/24 02:29 PM
03/05/24 02:29 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Originally Posted by lewtot184
8
A man of few words.
