Re: MPG
[Re: Kudakidd]
#3217498
03/02/24 03:05 PM
03/02/24 03:05 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
On the road cruising on light throttle pressures at or below 2500 RPM between 12.0 t0 15.0 MPG, around town depending on how your driving 6 to 10 MPG
Re: MPG
[Re: Kudakidd]
#3217539
03/02/24 06:22 PM
03/02/24 06:22 PM
Posts: 4,785 Star Idaho
67vertman
Star Idaho
It is a hot rod, I don't care what millage it gets. LOL My 440, fuel injected 6 Pac, 4:10 and Passion 4sp overdrive gets 11.2 mpg if I drive her gingerly. Real world every day driving is less than 10 mpg.
My Monster are real!
Living within your means makes life pretty easy.
Re: MPG
[Re: Kudakidd]
#3217545
03/02/24 07:08 PM
03/02/24 07:08 PM
Posts: 6,291 nowhere
Sniper
nowhere
Filling the tank and doing basic calculations isn't too accurate. TIA. It's a heck of a lot more accurate than any guess you'll get here. Why do you think it's not accurate?
Re: MPG
[Re: Kudakidd]
#3217577
03/02/24 09:01 PM
03/02/24 09:01 PM
Posts: 7,861 Witness Protection Program
Kudakidd
Some good real world info here. I was leaning toward about 8 mpg. I'm only saying that because the gas needle moves like a clock's second hand! Anyone come across magazine specs?
Re: MPG
[Re: Kudakidd]
#3217590
03/02/24 10:30 PM
03/02/24 10:30 PM
67vertman
Star Idaho
Back in the early 70s fuel mileage wasn't a big issue, but horse power ratings where.
Someone may have an old add or dealer ProMo that listed MPGs.
Re: MPG
[Re: Kudakidd]
#3217669
03/03/24 10:33 AM
03/03/24 10:33 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
As an addendum I'm taching 3,000rpm at 60 mph. I'd be thrilled with any mileage in the double digits! And I drive it like I had an egg under the go pedal. (Not all the time though. It is a Mopar!) Put a vacuum gauge in it. If it shows double digits at cruise, it should be dd mpg. Hook up your vacuum advance. Anything that will increase cruise vacuum helps MPG. Kevin
Re: MPG
[Re: PhillyRag]
#3217787
03/03/24 05:12 PM
03/03/24 05:12 PM
Posts: 5,334 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Matters if you take long trips. Otherwise, for the weekend occasional day trip/ride shouldn't matter. Are you planning on taking the car on a long trip in the near future? Is that why you want to get an MPG estimate?
Plymouth Makes It!
Re: MPG
[Re: RoadRunnerLuva]
#3217838
03/03/24 08:44 PM
03/03/24 08:44 PM
Posts: 10,605 Freeport IL USA
poorboy
Freeport IL USA
The trip odometer quit working on my truck about mid summer last year. Does you car still have a functioning odometer? Record the miles when you fill up, record the miles when you fill up the next time, and subtract the little number from the big number. Then divide that by the amount of gas you have added since the last fill up. the only way that is not accurate is if you didn't stop filling it at the same point each time. If you don't add any gas after the automatic shut off on the pump shuts off (buy the gas from the same pump from the same direction, at the same angle), you will be very close to getting the same fill each time.
I keep a little note book and a pen in the glove box to record the miles from the fast fill up. I can tell you pretty close how much gas its going to take to fill my truck up each time, based on the miles, and if it was all city, 1/2 city, or all highway driven. Any big block Mopar I ever had was between 8 mpg and 12mpg (that 12 was all highway).
Re: MPG
#3217848
03/03/24 09:08 PM
03/03/24 09:08 PM
Kudakidd
Matters if you take long trips. Otherwise, for the weekend occasional day trip/ride shouldn't matter. Are you planning on taking the car on a long trip in the near future? Is that why you want to get an MPG estimate? My idea of a long trip now is about 80 miles round trip.
