Organosol black other than PPG? #3214954
02/20/24 03:38 PM
02/20/24 03:38 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Being a PPG painter for 30 years I have found at times paint company's like to stop paint lines. Well for the longest time this black was only able spray it in Concept DCC single stage. Well they are no longer making Concept and my jobber is out of 2 toners for the color. I did call tech line and got a formula for a leaded formula as well as a Delfleet formula. Both of those formulas look like they will be very high in metallics and I don't feel the color would look right. So does anyone have any other paint lines they have messed with. This car I have to do I am getting close to just doing the parts in a semi gloss black as it is a 71 cuda that is not a restoration just getting a few areas colored in the black that should have been done when it was painted in the 90's.
corey
Contact Me about AMD Prices
Re: Organosol black other than PPG? [Re: hotairballoonpilot] #3214989
02/20/24 06:57 PM
02/20/24 06:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Have your jobber mix without the metallic ?
Spray a flat/flattened clear over the semi-gloss ?
There are a couple of other sources for a more accurate textured flat black.
(PS - love my yellow car - thanks again on that beer)
Re: Organosol black other than PPG? [Re: topside] #3215106
02/21/24 11:25 AM
02/21/24 11:25 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Have you checked with TCP Global? They mix many factory colors for antique and classic cars. I purchase their textured suede acrylic lacquer for my dash restorations.
Link to their restoration shop product lines: Link
Link to the 1970 Dodge color chart for reference: Link 2
You can find all makes and models in the Auto Color Library:
Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Organosol black other than PPG? [Re: hotairballoonpilot] #3215116
02/21/24 12:02 PM
02/21/24 12:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I did an imitation A12 hood, I used SEM hot rod black, and on the last couple coats I played with very low low air pressure and cross coating to achieve the texture.
I posted a thread about it in the projects area awhile back.
I'm happy with it, it duplicates the look of the nicest show cars I've seen.
And I believe the originals had quite a bit of variation to them as well.
Without the air pressure and texture games and just applied as you would any single stage, I thought it was a dead ringer for the tail panel finish on my 68 charger.
I covered that and posted at least one picture before adding texture in the same thread.
National Tool Warehouse had the best price.
Or there is always the Gibson/Badalson route $$$$$.
Rich H.
Esse Quam Videri
Re: Organosol black other than PPG? [Re: ZIPPY] #3215122
02/21/24 12:55 PM
02/21/24 12:55 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The Sherwin Williams Planet Color textured black in this thread looks promising if you can still locate it.
https://board.moparts.org/ubbthread...ead/Board/19/main/92448/type/thread.html
Re: Organosol black other than PPG? [Re: Neil] #3215128
02/21/24 01:20 PM
02/21/24 01:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
The local Painter Supply custom mixed up organisol for me in their paint line brand. Came out perfect for my lift off hood. Texture seemed spot on to me.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Organosol black other than PPG? [Re: Neil] #3215148
02/21/24 02:43 PM
02/21/24 02:43 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
That's my V21 Cuda. My painter buddy found that planet color textured paint for me
Re: Organosol black other than PPG? [Re: topside] #3215156
02/21/24 03:05 PM
02/21/24 03:05 PM
South Dakota
South Dakota
NP on the runner! Yeah I have been playing around in my head with all sort of ideas just hard to pull trigger in my mind on a few ideas.
On my dads 72 cuda I did the low pressure trick to get the texture look. My thought is I might just go with hot rod black and do the same trick. Thanks everyone
Re: Organosol black other than PPG? [Re: UCUDANT] #3215161
02/21/24 03:14 PM
02/21/24 03:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Yes, I remember way back when you were posting about that paint. It sure looks good in the photos. up
Re: Organosol black other than PPG? [Re: Neil] #3215173
02/21/24 04:07 PM
02/21/24 04:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Low pressure & fog final coat(s) from a distance has always worked for me.
True test for accuracy, as accomplished by a neighbor around 1970, though I DON'T recommend it:
Get a little paste wax on it, and if you can't get rid f the wax no matter what, you nailed it laugh2
Re: Organosol black other than PPG? [Re: topside] #3215219
02/21/24 07:39 PM
02/21/24 07:39 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
https://8774paint1.com/collections/specialty-paints-textured-argents-organisol
I used it on someone's else's car. Matched my of original formula cans great.
I think they stock piled old stuff. If it is not the old stuff. If not they figured out to match it's look, texture and metallic look right with what's currently available now.
I still have a quart of old PPG in my cabinet.
Looks the same. It's the best available if you want it right
When i shoot it, i do so over PPG DP90lf (black) used as reduced as sealer.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Organosol black other than PPG? [Re: hotairballoonpilot] #3215260
02/21/24 10:43 PM
02/21/24 10:43 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
