Re: 904/727 Trans with metal fluid line (not cooler lines)
[Re: Cab_Burge]
#3214762
02/19/24 09:33 PM
02/19/24 09:33 PM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
Vent? I wouldn't think a vent would come from the bottom of the trans (below fluid level).
[Re: A727Tflite]
#3214763
02/19/24 09:34 PM
02/19/24 09:34 PM
VITC_GTX
Looks like cooler lines - just routed to the passenger side.
Post a pic from the driver side. I never saw a AMC installation before but thats my guess. Not one of the two cooler lines. They are present on the left side of both transmissions.
[Re: VITC_GTX]
#3214777
02/19/24 10:24 PM
02/19/24 10:24 PM
Posts: 3,105 Michigan
A727Tflite
Post a pic from the driver side. I never saw a AMC installation before but thats my guess. Not one of the two cooler lines. They are present on the left side of both transmissions. Maybe a closeup to the line fitting under the extension. Only thing in the extension is the governor port - not sure why there would be a line to it.
[Re: A727Tflite]
#3214789
02/19/24 11:23 PM
02/19/24 11:23 PM
VITC_GTX
Post a pic from the driver side. I never saw a AMC installation before but thats my guess. Not one of the two cooler lines. They are present on the left side of both transmissions. Maybe a closeup to the line fitting under the extension. Only thing in the extension is the governor port - not sure why there would be a line to it. Ask and ye shall receive...
[Re: VITC_GTX]
#3214799
02/20/24 12:49 AM
02/20/24 12:49 AM
A727Tflite
I saw that pic earlier - was hoping for one a little closer and a better angle.
But, it looks like something attached to the governor pressure tap. Never seen anything like it before.
[Re: A727Tflite]
#3215000
02/20/24 07:38 PM
02/20/24 07:38 PM
Posts: 530 SW CO
HemiSportFury
SW CO
But, it looks like something attached to the governor pressure tap. Never seen anything like it before. Definitely looks like governor pressure line but what could they be using that for? Somehow tied in to cruise control or the speed governor on a truck?
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: HemiSportFury]
#3215026
02/20/24 10:10 PM
02/20/24 10:10 PM
VITC_GTX
But, it looks like something attached to the governor pressure tap. Never seen anything like it before. Definitely looks like governor pressure line but what could they be using that for? Somehow tied in to cruise control or the speed governor on a truck? The best guess over at the AMC forum is that it's part of the TCS (transmission Controlled Spark). That line goes up to a switch/solenoid that electrically controls something to do with spark advance I believe. I'm just trying to understand if I can remove the line and plug for my use. Kunkel, where are you at?
[Re: VITC_GTX]
#3215048
02/21/24 12:38 AM
02/21/24 12:38 AM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
I spoke with my Mopar Transmission builder . He had knowledge of this line . He said it ran up to something that had to do with retarding timing momentarily coordinating the shift with governor pressure for a smoother shift . He said it only came on a couple models like a Matador . He was a lot more detailed on his explanation , but I could only get a grasp of the basics , as it was a quick phone conversation . He said to put plug/cap at the transmission and Forget about it !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#3215058
02/21/24 03:35 AM
02/21/24 03:35 AM
VITC_GTX
I spoke with my Mopar Transmission builder . He had knowledge of this line . He said it ran up to something that had to do with retarding timing momentarily coordinating the shift with governor pressure for a smoother shift . He said it only came on a couple models like a Matador . He was a lot more detailed on his explanation , but I could only get a grasp of the basics , as it was a quick phone conversation . He said to put plug/cap at the transmission and Forget about it ! Thank you to you and your friend!!! I'm officially done worrying about it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
