904/727 Trans with metal fluid line (not cooler lines) #3214681
02/19/24 04:47 PM
02/19/24 04:47 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
So, I have an AMC 904 and it has a small metal fluid line coming out of the rear of the casing heading up towards the engine compartment. I plan on picking up an AMC 727 tomorrow from a guy two towns over and the pictures show it has the same metal line. These lines are not the typical cooling lines so what the heck is it??? I'm hoping I can block it off and ignore it.
I posted this question on the AMC forum and gotten a few ideas but nothing solid so let's see if the Mopart forum is smarted than the AMC forum grin
https://theamcforum.com/forum/904-transmission-question_topic122793_page1.html
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3214746
02/19/24 08:36 PM
02/19/24 08:36 PM
Vent? confused
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: Cab_Burge] #3214752
02/19/24 08:56 PM
02/19/24 08:56 PM
A727Tflite Online content
A727Tflite  Online Content
Looks like cooler lines - just routed to the passenger side.
Post a pic from the driver side. I never saw a AMC installation before but thats my guess.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: Cab_Burge] #3214762
02/19/24 09:33 PM
02/19/24 09:33 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Originally Posted by Cab_Burge
Vent? confused
I wouldn't think a vent would come from the bottom of the trans (below fluid level).
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: A727Tflite] #3214763
02/19/24 09:34 PM
02/19/24 09:34 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Not one of the two cooler lines. They are present on the left side of both transmissions.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3214773
02/19/24 10:15 PM
02/19/24 10:15 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Maybe to a pressure or temperature gauge????
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3214777
02/19/24 10:24 PM
02/19/24 10:24 PM
Maybe a closeup to the line fitting under the extension.
Only thing in the extension is the governor port - not sure why there would be a line to it.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: A727Tflite] #3214789
02/19/24 11:23 PM
02/19/24 11:23 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Ask and ye shall receive...
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3214799
02/20/24 12:49 AM
02/20/24 12:49 AM
I saw that pic earlier - was hoping for one a little closer and a better angle.
But, it looks like something attached to the governor pressure tap. Never seen anything like it before.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: A727Tflite] #3214845
02/20/24 10:06 AM
02/20/24 10:06 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Unless it's been damaged, the formed bend on the line does not look like any factory radius??
Joe
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: A727Tflite] #3215000
02/20/24 07:38 PM
02/20/24 07:38 PM
SW CO
HemiSportFury Offline
SW CO
Definitely looks like governor pressure line but what could they be using that for? Somehow tied in to cruise control or the speed governor on a truck?
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: HemiSportFury] #3215026
02/20/24 10:10 PM
02/20/24 10:10 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The best guess over at the AMC forum is that it's part of the TCS (transmission Controlled Spark). That line goes up to a switch/solenoid that electrically controls something to do with spark advance I believe.
I'm just trying to understand if I can remove the line and plug for my use.
Kunkel, where are you at?
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3215037
02/20/24 11:18 PM
02/20/24 11:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll agree with the otherss and you on possible uses. PLUG IT twocents beer
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3215038
02/20/24 11:18 PM
02/20/24 11:18 PM
If it’s attached to the governor port just plug it.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3215048
02/21/24 12:38 AM
02/21/24 12:38 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I spoke with my Mopar Transmission builder . He had knowledge of this line . He said it ran up to something that had to do with retarding timing momentarily coordinating the shift with governor pressure for a smoother shift . He said it only came on a couple models like a Matador . He was a lot more detailed on his explanation , but I could only get a grasp of the basics , as it was a quick phone conversation . He said to put plug/cap at the transmission and Forget about it !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: doctor_mopar] #3215058
02/21/24 03:35 AM
02/21/24 03:35 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thank you to you and your friend!!!
I'm officially done worrying about it up
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: VITC_GTX] #3215091
02/21/24 10:16 AM
02/21/24 10:16 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Perhaps share that information/discovery over on your AMC forum - if you haven't done so already.
Re: 904/727 Trans with metal fluid line (not cooler lines) [Re: EW1BH27] #3215119
02/21/24 12:15 PM
02/21/24 12:15 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
