68 Dart roll cage kit #3214542
02/19/24 09:01 AM
02/19/24 09:01 AM
Charlotte, NC
LSP Offline OP
LSP  Offline OP
Charlotte, NC
What's kits are out there that fits well, and will cert to 7.50?
Re: 68 Dart roll cage kit [Re: LSP] #3214566
02/19/24 10:33 AM
02/19/24 10:33 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
If you are looking for something that will cert to 7.50, I'd suggest a custom bent cage, and not a kit. Custom will fit MUCH better.
69 GTX 68 Road Runner
Re: 68 Dart roll cage kit [Re: JERICOGTX] #3214594
02/19/24 12:27 PM
02/19/24 12:27 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Agreed. Most kits are cut to fit anyway. A custom cage, you can get tighter bends and a tighter fitting, nicer appearance cage once done. Several bars have changed in recent years. Make sure you have an updated NHRA rule book, or use someone that is up to date on current certs/specs. 3 of my buddies cars failed the last 25.5 re-cert inspection, where my car still passed due to my OCD to begin with it still fell within the newer rules.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 68 Dart roll cage kit [Re: JERICOGTX] #3214610
02/19/24 01:43 PM
02/19/24 01:43 PM
iagree
My new drag car is already certed to 7.50 and I ask the chassis builder about updating it to 6.00 certs and he said no way, start from scratch or take it somewhere else.
You need to be very safe in any drag cars that go that fast, have it built for you up twocents
Re: 68 Dart roll cage kit [Re: Cab_Burge] #3214616
02/19/24 01:52 PM
02/19/24 01:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The local chassis shop that I used for a 6 pt. thought of things I hadn't considered.
Since they do it every day, they were able to fit it closely, turned it around quickly and made it look really nice!
In the broad scheme of things it was probably cheaper, too! What's your time worth?
Since you live in NASCAR country I would think you would have no shortage of guys that can whip up a cage for you!
'63 Dodge 330
11.19 @ 121 mph
Re: 68 Dart roll cage kit [Re: GY3] #3214638
02/19/24 02:35 PM
02/19/24 02:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ That's what I'm thinking - OP is probably not far from a mecca of fabrication.
Definitely need to refer to NHRA rulebook.
Problem with kits is some don't appear to fit tightly to the pillars, which not only looks unattractive but imposes more obstructions to seeing out of the car.
Re: 68 Dart roll cage kit [Re: LSP] #3214656
02/19/24 03:12 PM
02/19/24 03:12 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Chassis Works
THey have templates that you use to give them measurements. They custom bend it to your measurements
I did that for the 8.50 14pt cage, then just purchased the funny car cage kit.
Mine fits great and evertime it certs the NHRA guys ask me who built the car, it looks that good in there
....BAD A$$ STREET CAR.....
Re: 68 Dart roll cage kit [Re: n20mstr] #3214735
02/19/24 07:56 PM
02/19/24 07:56 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
First thing you need to buy, if you already haven't, is a copy of the SFI spec you're going to build to.
Read through it. Think about how you're going to get it all in there and welded up. Plenty of ways to skin that cat.
If you decide to cut the roof off and/or take the floor out, you won't be the first.
Re: 68 Dart roll cage kit [Re: CMcAllister] #3214759
02/19/24 09:25 PM
02/19/24 09:25 PM
AndyF Offline
AndyF  Offline
Yeah, at some point you either have to remove the floor or cut the roof of to make the cage correctly. Just depends on who is building the car and which tricks they like to use.
Re: 68 Dart roll cage kit [Re: AndyF] #3214769
02/19/24 09:57 PM
02/19/24 09:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We cut big enough holes at each location of the down bars so that we could set the cage down through the holes after everything was tach in. Welded everything up top and down on both sides as far as we could. Then set it back up in place finished welding the bottoms of the welds and added the remaining bars as needed. I then split the pieces we cut out of the floor at the centerline of each tube into two pieces, notched all of the floor pieces around the tubes and welded the factory floor pieces back in and welded the floor back to the tubes also.
