Re: 68 Dart roll cage kit
[Re: LSP]
#3214566
02/19/24 10:33 AM
02/19/24 10:33 AM
Posts: 10,022 MN
JERICOGTX
MN
What's kits are out there that fits well, and will cert to 7.50?
Thanks If you are looking for something that will cert to 7.50, I'd suggest a custom bent cage, and not a kit. Custom will fit MUCH better.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3214594
02/19/24 12:27 PM
02/19/24 12:27 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Thanks If you are looking for something that will cert to 7.50, I'd suggest a custom bent cage, and not a kit. Custom will fit MUCH better. Agreed. Most kits are cut to fit anyway. A custom cage, you can get tighter bends and a tighter fitting, nicer appearance cage once done. Several bars have changed in recent years. Make sure you have an updated NHRA rule book, or use someone that is up to date on current certs/specs. 3 of my buddies cars failed the last 25.5 re-cert inspection, where my car still passed due to my OCD to begin with it still fell within the newer rules.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: JERICOGTX]
#3214610
02/19/24 01:43 PM
02/19/24 01:43 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
Thanks If you are looking for something that will cert to 7.50, I'd suggest a custom bent cage, and not a kit. Custom will fit MUCH better. My new drag car is already certed to 7.50 and I ask the chassis builder about updating it to 6.00 certs and he said no way, start from scratch or take it somewhere else. You need to be very safe in any drag cars that go that fast, have it built for you
[Re: Cab_Burge]
#3214616
02/19/24 01:52 PM
02/19/24 01:52 PM
Posts: 4,672 Wichita
GY3
Wichita
The local chassis shop that I used for a 6 pt. thought of things I hadn't considered.
Since they do it every day, they were able to fit it closely, turned it around quickly and made it look really nice!
In the broad scheme of things it was probably cheaper, too! What's your time worth?
Since you live in NASCAR country I would think you would have no shortage of guys that can whip up a cage for you!
[Re: LSP]
#3214656
02/19/24 03:12 PM
02/19/24 03:12 PM
Posts: 4,676 On the parachute mount
n20mstr
Chassis Works
THey have templates that you use to give them measurements. They custom bend it to your measurements
I did that for the 8.50 14pt cage, then just purchased the funny car cage kit.
Mine fits great and evertime it certs the NHRA guys ask me who built the car, it looks that good in there
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3214735
02/19/24 07:56 PM
02/19/24 07:56 PM
Posts: 11,557 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
First thing you need to buy, if you already haven't, is a copy of the SFI spec you're going to build to.
Read through it. Think about how you're going to get it all in there and welded up. Plenty of ways to skin that cat.
If you decide to cut the roof off and/or take the floor out, you won't be the first.
[Re: AndyF]
#3214769
02/19/24 09:57 PM
02/19/24 09:57 PM
6PKRTSE
Motor City
We cut big enough holes at each location of the down bars so that we could set the cage down through the holes after everything was tach in. Welded everything up top and down on both sides as far as we could. Then set it back up in place finished welding the bottoms of the welds and added the remaining bars as needed. I then split the pieces we cut out of the floor at the centerline of each tube into two pieces, notched all of the floor pieces around the tubes and welded the factory floor pieces back in and welded the floor back to the tubes also.
