Milodon Gear Drive w/ 60MM cam #3214315
02/18/24 11:11 AM
02/18/24 11:11 AM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
Anyone install a Milodon 13000 gear dive on a 60mm Cam? I'm currently attempting, and the thrust bearing supplied only contacts the block about 1/8" of an inch. Searched high and low and there doesn't seem to be wider options. So just wondering if its a concern or not.
Re: Milodon Gear Drive w/ 60MM cam [Re: rt1976] #3214319
02/18/24 11:30 AM
02/18/24 11:30 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
You may have already looked here, but just for the heck of it:
[url=www.mcmaster.com/products/~/needle-roller-thrust-bearings/?s=torrington++thrust+bearing][/url]
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Milodon Gear Drive w/ 60MM cam [Re: 19swinger70] #3214321
02/18/24 11:41 AM
02/18/24 11:41 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: Milodon Gear Drive w/ 60MM cam [Re: rt1976] #3214472
02/18/24 10:00 PM
02/18/24 10:00 PM
AndyF Offline
AndyF  Offline
If Milodon doesn't have a solution then you'll have to engineer your own solution.
Re: Milodon Gear Drive w/ 60MM cam [Re: AndyF] #3214486
02/18/24 11:07 PM
02/18/24 11:07 PM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
Looking at it more today, I centered the lobes under the lifter bores and the cam would need to move about 3/8" rearward to allow the bearing to contact the block. I'm thinking the boss maybe was cut back to accommodate this and not need a bearing.
Going to make some phone calls tomorrow and find out.
Re: Milodon Gear Drive w/ 60MM cam [Re: rt1976] #3214512
02/19/24 02:46 AM
02/19/24 02:46 AM
Man that is massive core shift,, are you sure it will work fine for you shruggy work scope twocents
I would at least check #1 and #6 cam timing in relation to TDC to make sure their is absolutely no differences in the cam timing on the passenger side from the drivers side
Re: Milodon Gear Drive w/ 60MM cam [Re: Cab_Burge] #3214513
02/19/24 02:51 AM
02/19/24 02:51 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
so that block casting allows for a raised cam option?
Re: Milodon Gear Drive w/ 60MM cam [Re: rt1976] #3214529
02/19/24 07:27 AM
02/19/24 07:27 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I personally don't like the limited surface contact FWIW. You may have to source a bronze bushing, no harm. ALSO, it doesn't appear the cam is piloted now with what you have going? From what I have seen the depth of the undercut on cams bigger than OEM diameter is cut as-if you were just putting a timing chain on it. I've had to lathe a couple of 3 cams on the front undercut deeper to get the stack-up correct for my Jesel belt.
Re: Milodon Gear Drive w/ 60MM cam [Re: jcc] #3214541
02/19/24 08:57 AM
02/19/24 08:57 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yes that is for raised cam..
That's not core shift.
Re: Milodon Gear Drive w/ 60MM cam [Re: HardcoreB] #3214543
02/19/24 09:10 AM
02/19/24 09:10 AM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
I was thinking the same on the bronze bushing if needed, those I can find w/ proper ID/OD. What do you mean by piloted? Sorry I'm used to small blocks. Thanks
