Re: Milodon Gear Drive w/ 60MM cam
[Re: rt1976]
#3214319
02/18/24 11:30 AM
02/18/24 11:30 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
You may have already looked here, but just for the heck of it: [url=www.mcmaster.com/products/~/needle-roller-thrust-bearings/?s=torrington++thrust+bearing][/url]
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: AndyF]
#3214486
02/18/24 11:07 PM
02/18/24 11:07 PM
Posts: 38 indianapolis, in
rt1976
indianapolis, in
Looking at it more today, I centered the lobes under the lifter bores and the cam would need to move about 3/8" rearward to allow the bearing to contact the block. I'm thinking the boss maybe was cut back to accommodate this and not need a bearing. Going to make some phone calls tomorrow and find out.
[Re: Cab_Burge]
#3214513
02/19/24 02:51 AM
02/19/24 02:51 AM
Posts: 22,696 Bitopia
jcc
Bitopia
so that block casting allows for a raised cam option?
[Re: rt1976]
#3214529
02/19/24 07:27 AM
02/19/24 07:27 AM
Posts: 4,054 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Anyone install a Milodon 13000 gear dive on a 60mm Cam? I'm currently attempting, and the thrust bearing supplied only contacts the block about 1/8" of an inch. Searched high and low and there doesn't seem to be wider options. So just wondering if its a concern or not.
Thanks I personally don't like the limited surface contact FWIW. You may have to source a bronze bushing, no harm. ALSO, it doesn't appear the cam is piloted now with what you have going? From what I have seen the depth of the undercut on cams bigger than OEM diameter is cut as-if you were just putting a timing chain on it. I've had to lathe a couple of 3 cams on the front undercut deeper to get the stack-up correct for my Jesel belt.
[Re: jcc]
#3214541
02/19/24 08:57 AM
02/19/24 08:57 AM
Posts: 1,991 Apollo, PA.
B1MAXX
Apollo, PA.
so that block casting allows for a raised cam option? Yes that is for raised cam.. That's not core shift.
[Re: HardcoreB]
#3214543
02/19/24 09:10 AM
02/19/24 09:10 AM
rt1976
indianapolis, in
Thanks I personally don't like the limited surface contact FWIW. You may have to source a bronze bushing, no harm. ALSO, it doesn't appear the cam is piloted now with what you have going? From what I have seen the depth of the undercut on cams bigger than OEM diameter is cut as-if you were just putting a timing chain on it. I've had to lathe a couple of 3 cams on the front undercut deeper to get the stack-up correct for my Jesel belt. I was thinking the same on the bronze bushing if needed, those I can find w/ proper ID/OD. What do you mean by piloted? Sorry I'm used to small blocks. Thanks
