CORRECT CARB FOR 1971 CUDA 383 #3212941
02/12/24 01:25 AM
02/12/24 01:25 AM
Sweden
71redcuda Offline OP
Sweden
Hello,
I would like to know the correct carburator for a
71 Cuda 383 with auto..
Im guessing Carter AVS 6125 ?
Nicklas
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 71redcuda] #3212944
02/12/24 01:44 AM
02/12/24 01:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it would be a HOLLEY 4160 # R4735 with auto/with N96 and # R4668 with auto/without N96
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 6bblgt] #3212945
02/12/24 01:47 AM
02/12/24 01:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1971
383 manual - E & B-body
orange HP engine
---------- Holley R4667A ---------- part number 3512 848 on b'cast 48
383 manual - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4734A ---------- part number 3512 849 on b'cast 49
***** some sources show the following manual trans carbs with the same part numbers *****
orange HP engine
---------- Holley R6191A ---------- part number 3512 848 on b'cast 48
orange HP engine
---------- Holley R6193A ---------- part number 3512 849 on b'cast 49
383 automatic - C-body
blue engine
---------- Carter 6125S ---------- part number 3512 844 on b'cast 44
383 automatic - E & B-body
orange HP engine
---------- Holley R4668A ---------- part number 3512 830 on b'cast 30
383 automatic - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4735A ---------- part number 3512 842 on b'cast 42
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 6bblgt] #3212955
02/12/24 03:42 AM
02/12/24 03:42 AM
Sweden
Sweden
Good info, thank you!
See if its possible to find one.. its for a friend that is restoring a car.
Nicklas
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 71redcuda] #3212984
02/12/24 10:49 AM
02/12/24 10:49 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Funny, I just picked up 2-4668s and 1-6191, been looking for a long time, they special
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: cudaman1969] #3212990
02/12/24 11:07 AM
02/12/24 11:07 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have two 71 383's laying around and just found an intake with a Holley on it, where are the numbers located on it?
JB Rhinehart, Realist
A-Body's RULE!
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: Rhinodart] #3213053
02/12/24 03:24 PM
02/12/24 03:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
on the air horn scope
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 6bblgt] #3213071
02/12/24 05:11 PM
02/12/24 05:11 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Didn’t all those mentioned 1971 Holleys get thrown in the garbage at the dealerships when they got replaced with the Carter AVS 6125s due to leakage and fires
That’s why they are so hard to find
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: bee1971] #3213261
02/13/24 05:10 PM
02/13/24 05:10 PM
MN
Droop69 Offline
Droop69  Offline
MN
71 Cuda N96 4 speed carb. Original to my car Holley.
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: Droop69] #3213265
02/13/24 05:31 PM
02/13/24 05:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
See those back Venturi’s, that’s what is unique about these carbs, 70-71 383 only. My new 70 Challenger had the 4 speed 383 with that carb, when secondaries came in it was a rush!
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: cudaman1969] #3213412
02/14/24 07:32 AM
02/14/24 07:32 AM
Sweden
Sweden
Hi,
Just found one here locally in Sweden.
Nicklas
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: 71redcuda] #3213594
02/14/24 08:40 PM
02/14/24 08:40 PM
MoreParts Offline
MoreParts  Offline
Some of these 383s get a lean spot or stumble. If you find yourself in that situation get yourself the kit mentioned in this TSB on ePay or separately. The kit is pretty cheap if you can find it.
https://www.e-bodies.org/Resources/TSB/Carb_Engine_Lag_Stumble.pdf
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: MoreParts] #3213634
02/14/24 11:54 PM
02/14/24 11:54 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That’s pretty much what I did for all the later race cars with Hollys. The Challenger did have a stumble but I attributed it to that big electric vacuum advance but didn’t know sh!t from apple butter back then to fix it.
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: MoreParts] #3213670
02/15/24 09:28 AM
02/15/24 09:28 AM
MN
Droop69 Offline
Droop69  Offline
MN
I wonder what size nozzle was in the kit?
Re: CORRECT CARB FOR 1971 CUDA 383 [Re: Droop69] #3213738
02/15/24 01:56 PM
02/15/24 01:56 PM
MoreParts Offline
MoreParts  Offline
I see a couple of sets on ePay now. You may be able to get that info from one of the sellers. Going from my shotty memory though I think they were 3 to 5 sizes larger than stock. It was right at the number Holley recommends going to the hollow hold down screw for better flow.
