Re: CORRECT CARB FOR 1971 CUDA 383
[Re: cudaman1969]
#3212990
02/12/24 11:07 AM
02/12/24 11:07 AM
Posts: 43,552 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have two 71 383's laying around and just found an intake with a Holley on it, where are the numbers located on it?
JB Rhinehart, Realist
A-Body's RULE!
[Re: 6bblgt]
#3213071
02/12/24 05:11 PM
02/12/24 05:11 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Didn’t all those mentioned 1971 Holleys get thrown in the garbage at the dealerships when they got replaced with the Carter AVS 6125s due to leakage and fires
That’s why they are so hard to find
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Droop69]
#3213265
02/13/24 05:31 PM
02/13/24 05:31 PM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
71 Cuda N96 4 speed carb. Original to my car Holley. See those back Venturi’s, that’s what is unique about these carbs, 70-71 383 only. My new 70 Challenger had the 4 speed 383 with that carb, when secondaries came in it was a rush!
[Re: 71redcuda]
#3213594
02/14/24 08:40 PM
02/14/24 08:40 PM
MoreParts
Some of these 383s get a lean spot or stumble. If you find yourself in that situation get yourself the kit mentioned in this TSB on ePay or separately. The kit is pretty cheap if you can find it. https://www.e-bodies.org/Resources/TSB/Carb_Engine_Lag_Stumble.pdf
