rocker arm question #3206795
01/21/24 11:54 AM
01/21/24 11:54 AM
BigFish69 Offline OP
Are rocker arms the same between sbm and bbm besides the length of the shafts.
Re: rocker arm question [Re: BigFish69] #3206802
01/21/24 12:06 PM
01/21/24 12:06 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
To save someone coming on here and starting a debate I’ll let you fill in the answer but I’ll tell you this. Edelbrock recommends big block rockers on their Victor small block heads. And Indy says their 440-1 rockers are good on 360-1 heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: rocker arm question [Re: pittsburghracer] #3206813
01/21/24 12:19 PM
01/21/24 12:19 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Nope, pushrod offset, and fulcrum length is different, when talking stock stuff but aftermarket heads could be different.
Re: rocker arm question [Re: pittsburghracer] #3207004
01/21/24 09:14 PM
01/21/24 09:14 PM
What i have is a set of old crane golds off a 440 that i wanted to use on set of trick flows just a street cruiser
Re: rocker arm question [Re: BigFish69] #3207088
01/22/24 08:56 AM
01/22/24 08:56 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The pushrods are offset on Big blocks, both the intake and exhaust. The small block rockers are on center.
I'll have to check on the fulcrum length. I think I have both rockers laying around.
Re: rocker arm question [Re: B1MAXX] #3207881
01/24/24 06:13 PM
01/24/24 06:13 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The fulcrum length is different. But I guess that's only one part of the equation though.
The pushrod side should be disregarded,one is 1.6 and one is 1.5
Re: rocker arm question [Re: B1MAXX] #3207892
01/24/24 06:41 PM
01/24/24 06:41 PM
Thanks for your reply can't hardly win at this game time to spend more money.
Re: rocker arm question [Re: BigFish69] #3208038
01/25/24 09:29 AM
01/25/24 09:29 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Throw an intake and an exhaust on a head and see what it looks like! That's engine building. Even if what you have if 'off' B3 makes fulcrum position altering kits that'll probably make what you have useable.
Re: rocker arm question [Re: B1MAXX] #3208044
01/25/24 09:43 AM
01/25/24 09:43 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This pic is worth a thousand words. I assume that these Cranes are both for a BigBlock and one is called a 1.5 and the other a 1.6 ratio. But unless it's a major illusion there are distinct differences between the pivot and pushrod end making these closer to the same actual ratio REGARDLESS of what it's labeled. Even more reason to mock things up and see.
Re: rocker arm question [Re: HardcoreB] #3208045
01/25/24 09:47 AM
01/25/24 09:47 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The company name is B3RE.
Re: rocker arm question [Re: HardcoreB] #3208097
01/25/24 01:34 PM
01/25/24 01:34 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
No, he wanted to see a small block one vs a big block. Thats what those are. I agree though you never know what the head mfg. used for dimensions,. can't hurt to check it out.
Re: rocker arm question [Re: HardcoreB] #3208165
01/25/24 08:16 PM
01/25/24 08:16 PM
will give it a try i'm familiar with B3RE
thanks
Re: rocker arm question [Re: BigFish69] #3208202
01/26/24 12:12 AM
01/26/24 12:12 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
From the T&D catalog. Small block.
Part No. Description Length Int O/S Exh O/S Foot Notes
MOPAR CASTINGS & SMALL BLOCK WEDGE
8002 W-2 W-5 Race w/5.350” valves 1.450 0.700 0.080 1,2,3,5,11,12,15,50,51,55,70,104
8005 W-2 W-5 Race w/5.140” valves 1.520 0.700 0.080 1,2,3,11,12,15,50,51,55,70,104
8007 Magnum R/T 1.450 0.170 0.150 1,2,3,12,16,41,55,104,130
8008 OEM Iron 273-360 5/8 shaft 1.450 O/C 0.080 1,2,3,12,41,50,55,70,104,130
8009 Magnum 318-360 5/8 shaft 1.450 0.080 O/C 1,2,3,12,16,41,55,104,130
8075 Slant 6 (rockers and shims only) 1.850 O/C O/C 2,13,55,73,133,141
8080 W-7 W-8 w/standard bolt pattern 1.650 0.550 O/C 3,10,13,30,55,60,70,109,130
8090 W-7 W-8 w/ “W” bolt pattern 1.650 0.550 0.150 1,3,10,13,30,55,60,70,109,130
8095 W-9 1.650 0.550 0.080 1,3,10,13,30,55,62,70,109,130
8097 W-9 RP 1.650 0.775 0.150 1,3,10,13,30,55,62,70,109,130
8100 Econo W-2 single shaft OEM replace 1.520 0.700 0.150 1,2,3,50,55,73,102,105,133
8110 OEM Iron 273-360 single shaft 1.520 O/C O/C 1,2,3,6,13,50,55,73,103,105,133
8115 T/A 340 Iron single shaft OEM 1.520 0.450 0.080 1,2,3,13,50,55,73,103,105,133
Floyd Lippencott IV
Re: rocker arm question [Re: mr_340] #3208203
01/26/24 12:14 AM
01/26/24 12:14 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
From the T&D catalog. Big block.
MOPAR CASTINGS BIG BLOCK WEDGE
8200 383-440 sing-shft 452,906,915 Stg V 1.520 0.250 0.080 1,3,6,10,13,51,55,60,73,104,133
8201 383-440 Stg VI Max Wedge sng-shft 1.520 0.465 0.080 1,3,10,13,51,55,60,73,104,133
8202 383-440 Stg VI Chapman 1.520 0.800 O/C 1,3,10,13,51,55,60,73,104,133
8231 383-440 5/8 shaft 1.650 0.170 0.080 2,11,15,30,55,60,74,109,130
Floyd Lippencott IV
Re: rocker arm question [Re: mr_340] #3208220
01/26/24 07:15 AM
01/26/24 07:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Crane fulcrum length on a small block is a touch short to begin with. Mock them up.
Doug
Re: rocker arm question [Re: dvw] #3214530
02/19/24 07:40 AM
02/19/24 07:40 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What ever happened here? Did you get a working solution?
Re: rocker arm question [Re: HardcoreB] #3214843
02/20/24 09:47 AM
02/20/24 09:47 AM
have not address it yet it was for a future build
