rocker arm question
#3206795
01/21/24 11:54 AM
01/21/24 11:54 AM
Posts: 482 Michigan
BigFish69
Are rocker arms the same between sbm and bbm besides the length of the shafts.
Re: rocker arm question
[Re: BigFish69]
#3206802
01/21/24 12:06 PM
01/21/24 12:06 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Are rocker arms the same between sbm and bbm besides the length of the shafts. To save someone coming on here and starting a debate I’ll let you fill in the answer but I’ll tell you this. Edelbrock recommends big block rockers on their Victor small block heads. And Indy says their 440-1 rockers are good on 360-1 heads.
[Re: B1MAXX]
#3207881
01/24/24 06:13 PM
01/24/24 06:13 PM
Posts: 1,992 Apollo, PA.
B1MAXX
Apollo, PA.
The fulcrum length is different. But I guess that's only one part of the equation though. The pushrod side should be disregarded,one is 1.6 and one is 1.5
[Re: BigFish69]
#3208038
01/25/24 09:29 AM
01/25/24 09:29 AM
Posts: 4,057 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Thanks for your reply can't hardly win at this game time to spend more money. Throw an intake and an exhaust on a head and see what it looks like! That's engine building. Even if what you have if 'off' B3 makes fulcrum position altering kits that'll probably make what you have useable.
[Re: B1MAXX]
#3208044
01/25/24 09:43 AM
01/25/24 09:43 AM
HardcoreB
Shelby Twp. Mi
The fulcrum length is different. But I guess that's only one part of the equation though. The pushrod side should be disregarded,one is 1.6 and one is 1.5 This pic is worth a thousand words. I assume that these Cranes are both for a BigBlock and one is called a 1.5 and the other a 1.6 ratio. But unless it's a major illusion there are distinct differences between the pivot and pushrod end making these closer to the same actual ratio REGARDLESS of what it's labeled. Even more reason to mock things up and see.
[Re: HardcoreB]
#3208097
01/25/24 01:34 PM
01/25/24 01:34 PM
B1MAXX
Apollo, PA.
The fulcrum length is different. But I guess that's only one part of the equation though. The pushrod side should be disregarded,one is 1.6 and one is 1.5 This pic is worth a thousand words. I assume that these Cranes are both for a BigBlock and one is called a 1.5 and the other a 1.6 ratio. But unless it's a major illusion there are distinct differences between the pivot and pushrod end making these closer to the same actual ratio REGARDLESS of what it's labeled. Even more reason to mock things up and see. No, he wanted to see a small block one vs a big block. Thats what those are. I agree though you never know what the head mfg. used for dimensions,. can't hurt to check it out.
[Re: BigFish69]
#3208202
01/26/24 12:12 AM
01/26/24 12:12 AM
Posts: 3,505 DFW
mr_340
DFW
From the T&D catalog. Small block. Part No. Description Length Int O/S Exh O/S Foot Notes MOPAR CASTINGS & SMALL BLOCK WEDGE 8002 W-2 W-5 Race w/5.350” valves 1.450 0.700 0.080 1,2,3,5,11,12,15,50,51,55,70,104 8005 W-2 W-5 Race w/5.140” valves 1.520 0.700 0.080 1,2,3,11,12,15,50,51,55,70,104 8007 Magnum R/T 1.450 0.170 0.150 1,2,3,12,16,41,55,104,130 8008 OEM Iron 273-360 5/8 shaft 1.450 O/C 0.080 1,2,3,12,41,50,55,70,104,130 8009 Magnum 318-360 5/8 shaft 1.450 0.080 O/C 1,2,3,12,16,41,55,104,130 8075 Slant 6 (rockers and shims only) 1.850 O/C O/C 2,13,55,73,133,141 8080 W-7 W-8 w/standard bolt pattern 1.650 0.550 O/C 3,10,13,30,55,60,70,109,130 8090 W-7 W-8 w/ “W” bolt pattern 1.650 0.550 0.150 1,3,10,13,30,55,60,70,109,130 8095 W-9 1.650 0.550 0.080 1,3,10,13,30,55,62,70,109,130 8097 W-9 RP 1.650 0.775 0.150 1,3,10,13,30,55,62,70,109,130 8100 Econo W-2 single shaft OEM replace 1.520 0.700 0.150 1,2,3,50,55,73,102,105,133 8110 OEM Iron 273-360 single shaft 1.520 O/C O/C 1,2,3,6,13,50,55,73,103,105,133 8115 T/A 340 Iron single shaft OEM 1.520 0.450 0.080 1,2,3,13,50,55,73,103,105,133
Floyd Lippencott IV
[Re: mr_340]
#3208203
01/26/24 12:14 AM
01/26/24 12:14 AM
Posts: 3,505 DFW
mr_340
DFW
From the T&D catalog. Big block. MOPAR CASTINGS BIG BLOCK WEDGE 8200 383-440 sing-shft 452,906,915 Stg V 1.520 0.250 0.080 1,3,6,10,13,51,55,60,73,104,133 8201 383-440 Stg VI Max Wedge sng-shft 1.520 0.465 0.080 1,3,10,13,51,55,60,73,104,133 8202 383-440 Stg VI Chapman 1.520 0.800 O/C 1,3,10,13,51,55,60,73,104,133 8231 383-440 5/8 shaft 1.650 0.170 0.080 2,11,15,30,55,60,74,109,130
Floyd Lippencott IV
