Page 2 of 3 1 2 3
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3200674
12/29/23 01:14 PM
12/29/23 01:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
6 pac piston rod and pin
Piston 920
Rod 901
pin 251
440 stock pin 223
Stock 68 440 piston rod pin together 1932.5
6pac together 2071.2
68 piston 866 pin 223
Those 866 pistons came out of a 74 440 motor home block had 6 pac rods and steel crank and internally balanced, regular balancer.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200676
12/29/23 01:18 PM
12/29/23 01:18 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
I checked out the ross pistons #80762 ...like good, ..... i think with a 88cc head with a #40 felpro head gasket comp around 11.00 to 11.25 ...............i have not checked out the price yet. ?
Re: 440 six pack stock rods crank gram weight ? [Re: cudaman1969] #3200682
12/29/23 01:24 PM
12/29/23 01:24 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thank you i really needed that info cudaman 69 .......... is it the same with a HP block ???
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3200696
12/29/23 02:23 PM
12/29/23 02:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Reg piston was not in a HP block but the combined one was. Slight difference in height between the 2, 68 being taller but neither as tall as the 6 pac. Remember the 69-1/2 6 pac had the regular pistons and LY rods, 70-71 had the high compression 4 valve notch pistons and big rods, externally balanced. I’m thinking the LY rod and lighter pin would get close to the regulars setup with internal balance, with a little metal removal in the piston (30 grams). That’s what I’m looking to do
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3200749
12/29/23 06:31 PM
12/29/23 06:31 PM
PA
Scully Offline
Scully  Offline
PA
You need the small and big end weights for the rod to calculate the bob weight.
Re: 440 six pack stock rods crank gram weight ? [Re: Scully] #3200863
12/30/23 09:58 AM
12/30/23 09:58 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
2 big ends+ 2 con. bearing sets+ 1 little end+ 1 ring set+ 1 piston +1 pin + any locks for one piston+ (oil of choice usually 5/6 gr.)= bobweight.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200909
12/30/23 01:10 PM
12/30/23 01:10 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thank you sir, it has been a struggle matching parts ! all the stroker kits from Jegs ...........need balancing too ! *&^%$#@! it is hard when you have not bought the pistons yet,.........LOL LOL
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3201900
01/03/24 11:43 AM
01/03/24 11:43 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Why can't some body made a affordable forged piston with a compression radio around 11.00 to 11.50 with a open chamber head in a stock block ? ..................... please i don't understand !
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3201978
01/03/24 04:32 PM
01/03/24 04:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Because aftermarket choices are bleak to non existent for mopars... now it it were a chevy or smallblock ford ...
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3201989
01/03/24 05:51 PM
01/03/24 05:51 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
I got a set of trw forged designed for open chamber
.60 over they are close to 11 to 1 I never measured weight but I heard they are stock cast piston weight
Re: 440 six pack stock rods crank gram weight ? [Re: d-150] #3202178
01/04/24 11:37 AM
01/04/24 11:37 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Did you get your pistons from Jegs/summit/ or from there web-site ?
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3202212
01/04/24 02:06 PM
01/04/24 02:06 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
They are old stock 2295. I think they used to call them 6 pack pistons
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3202235
01/04/24 04:39 PM
01/04/24 04:39 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
There isa set on eBay for 60 bucks
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3202237
01/04/24 04:50 PM
01/04/24 04:50 PM
AndyF Offline
AndyF  Offline
Because that is a bad combination. Most customers want a combination that they can daily drive with pump gas. A modern closed chamber aluminum head with 10:1 compression using an off the shelf flat top piston makes great power and works with pump gas.
Re: 440 six pack stock rods crank gram weight ? [Re: d-150] #3202354
01/05/24 02:41 AM
01/05/24 02:41 AM
PA
Scully Offline
Scully  Offline
PA
The TRW 6 Pack pistons have 4 notches and are identical to the stock ones in shape.
Re: 440 six pack stock rods crank gram weight ? [Re: Scully] #3202366
01/05/24 08:44 AM
01/05/24 08:44 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yep, the 2295 are what gets termed "old trw dome tops".
The six pac is 2355
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3202416
01/05/24 11:47 AM
01/05/24 11:47 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thanks all the pistons for-sale i have seen are the low compression one's
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3202453
01/05/24 01:39 PM
01/05/24 01:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What heads are you using ?
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3202488
01/05/24 03:26 PM
01/05/24 03:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Then they’re not 6 pac pistons, should be 2.05 compression height at least.
Re: 440 six pack stock rods crank gram weight ? [Re: JohnRR] #3203179
01/08/24 11:38 AM
01/08/24 11:38 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Im using #452 heads for unleaded gas
Page 2 of 3 1 2 3
