Why can't some body made a affordable forged piston with a compression radio around 11.00 to 11.50 with a open chamber head in a stock block ? ..................... please i don't understand !
Because that is a bad combination. Most customers want a combination that they can daily drive with pump gas. A modern closed chamber aluminum head with 10:1 compression using an off the shelf flat top piston makes great power and works with pump gas.
