Re: We’re you happy with your Borgeson steering box swap?
[Re: migsBIG]
#3194803
12/02/23 12:17 AM
12/02/23 12:17 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Mine is yet to be installed. It will get in around the time they offer a mopar 12:1? box is my guess.
[Re: migsBIG]
#3194970
12/02/23 07:27 PM
12/02/23 07:27 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I just went through this install towards the later part of the crusing season, so I don't have a couple of thousand of KMs to remark about, but for what it's worth.... So to baseline my feeback, I started with the following combination: 1) 1980 M-body Coupe, using a pretty tight factory box (literally no float in the middle) 2) previously installed the pressure-drop shim kit in my power steering pump, so the ride was already pretty tight feeling, but yes, that good ol' Mopar squirly feeling was still there 3) my Coupe is set up with handling as the focus, so fleet car large sway bars, KONI adjustable shocks, all new suspension pieces with about 6K miles since a total rubuild Alright, so following the install I will say this: 1) there is noticable improvement in ride stability, no doubt about it 2) was it a 'Day & Night' type of a thing...??? Nope, not for me, but I attribute that to the decent handling baseline I started off with 3) what AndyF remarked on was very true for me as well, and a real PITA at that...trying to find the right fittings to bolt it all together...my oh my, it felt I was literally hacking this thing together at times - here is a Moparts thread of mine on this very topic - I am running a power steering cooler, so perhaps that complicated things a tad more - the power steering pump high-pressure hose used by the factory uses a weird (to me LOL) fitting, it's not a straight forward flare, rather it's an O-ring type retaining flare (for a decent pic and description of this check out the above thread I linked above) 4) I did actually run into an issue with the 1st unit they shipped, cross threaded bolts on the head piece (2 of 4), the exchange unit had a crooked dust seal on the pitman shaft, which I was able to correct, see this thread5) finally, last but not least, take a look at the attached photo, those are 1-7/8" TTI pipes and while I do have a pretty good amount of room, but it gets HOT HOT HOT...so I am planning on wrapping the power steering hoses with some heat deflecting sleeves Ohhh...almost forgot: I made up my own direct-fit-coupler. Basically took a factory piece and had a local race shop weld on the fitting with the correct spline count. Yes, you can get these on-line from Bergman, but holy molly the price...I couldn't afford that!
Last edited by Diplomat360; 12/03/23 02:01 PM. Reason: Added the two separate Moparts threads of mine...
[Re: topside]
#3195109
12/03/23 01:29 PM
12/03/23 01:29 PM
Posts: 4,733 Florida
BDW
I'll go against the grain and say it wasn't worth it for me. My experience is similar to Diplomat's, I put in a "cop box" in the 90's when you could still get them at Advance Auto. I later did the shim upgrade too, and the steering was great. I only decided to go Borg because of my Gen3 swap for added space. As mentioned, it was a cumbersome install working through various issues. I actually put the box in while the 340 was still in the car and drove it 6 months before the motor swap. The 5.7 is in the car with the Holley power steering swap pump. Had to get new fittings and custom hose made, it works, with the hissing at low RPM everyone mentions.
Since then, I have seen several other E-bodies with the Gen3 swap using factory gear at car shows.
Take this with the understanding I'm "budget minded", so this was a waste for me. The $1k could have been used several other places. Does it have better feel than what I had? Maybe, but hardly noticeable. The car is a cruiser and not autocrossed, but again, I can't tell the difference.
This mod seems to be in the category of " I've done everything else and seems cool"
[Re: BDW]
#3195117
12/03/23 02:19 PM
12/03/23 02:19 PM
jcc
Bitopia
Not yet mentioned, but I thought this box had like a one? point faster steering ratio over an OEM PS box, granted not much, but nobody has even commented on that aspect as if it's not even noticeable?
[Re: jcc]
#3195121
12/03/23 02:54 PM
12/03/23 02:54 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
Not yet mentioned, but I thought this box had like a one? point faster steering ratio over an OEM PS box, granted not much, but nobody has even commented on that aspect as if it's not even noticeable? The OP asked for opinions on the kit and he's gotten them. The bottom line appears to be, Is the paint worth the gain ? that is what every one is commenting on. I actually got to one of their senior tech guys while trying to sort out issues with a Mustang install. After getting to know him, he admitted it started with one kit for Something like a tri five Chev or cashmaro. He said the interest and sales were beyond expectations. So they figured they were on to something and started using the same box in A LOT of different app's by changing the weldment /adapter. Little NO actual testing was done on actual installs. He also admitted they were winging it as the owner and his son moved to Tennessee (I think) and were concentrating on making Custom guns. Research at the time confirmed this. He further said they really didn't have any actual Engineers in house just staff left over from the U-Joint days which is where the old man made his $$ As I stated earlier, I have installed quite a few and everyone was a PITA. groaning, box to column alignment, pitman arm and center link alignment issues and the list goes on. We didn't have issues with the hoses as we usually made our own. BTW, I'm not trying to be offensive to you in anyway
[Re: jcc]
#3195138
12/03/23 03:29 PM
12/03/23 03:29 PM
Posts: 31,046 Oregon
AndyF
Not yet mentioned, but I thought this box had like a one? point faster steering ratio over an OEM PS box, granted not much, but nobody has even commented on that aspect as if it's not even noticeable? It is a good ratio and I think the install was well worth the effort on my Coronet. The Coronet was a hassle to drive with a manual box and now it is very easy to drive. It isn't over powered and soft like the OEM Mopar PS boxes, it is nice and stiff like a modern PS system. I guess my main point is that the install was a hassle for me and at the time I was working in a very well equipped shop. I also have the ability to fabricate almost anything that is required for any hot rod project. So if it was a hassle for me it could prove to be really difficult for someone working in their driveway with just a claw hammer and a screw driver.
[Re: TJP]
#3195148
12/03/23 03:49 PM
12/03/23 03:49 PM
jcc
Bitopia
Not yet mentioned, but I thought this box had like a one? point faster steering ratio over an OEM PS box, granted not much, but nobody has even commented on that aspect as if it's not even noticeable? .... ...............BTW, I'm not trying to be offensive to you in anyway No Harm no foul. Me being here for over a decade, your last sentiment puts you into a very small crowd is my observation.
[Re: AndyF]
#3195153
12/03/23 04:08 PM
12/03/23 04:08 PM
Diplomat360
Windsor, ON, Canada
...I guess my main point is that the install was a hassle for me and at the time I was working in a very well equipped shop. I also have the ability to fabricate almost anything that is required for any hot rod project. So if it was a hassle for me it could prove to be really difficult for someone working in their driveway with just a claw hammer and a screw driver... This UP here is the key point: I was lucky enough to have a Mopar buddy give me his high-pressure hose and a couple of fittings, which helped significantly, otherwise I would basically have the BOX...and....ummm, lots of questions how to button it all up!!!
[Re: Car Nut]
#3195211
12/03/23 08:13 PM
12/03/23 08:13 PM
Posts: 4,431 Michigan
MarkZ
Worthy
Worthy
I really do not understand the issues people have been having. I ordered everything through Bergman Autocraft so it included all the fittings, hoses and his column adapter. Box went right in without so much on an issue. This is on an M body that nobody makes [censored] for or even takes into consideration when designing kits. Completely took the slop out of the steering. I've installed two of these kits on separate cars. Just order it all through Bergman!
