a998 SHIFT ISSUE #3192055
11/19/23 04:54 PM
11/19/23 04:54 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
OK, bought this Magnum a couple years ago. Has sat virtually the whole time except for a couple very short runs.
Drove it to the license bureau for a title inspection, and noticed it shifts great, EXCEPT for when it hit 3rd. It acts like it's slipping horribly bad. Drop it back in 2, then back to 3, a couple times it would stay engaged but eventually start to slip
Fearing the worst, but once or twice it did stay engaged for a while. Sometimes dropping it back in 2nd and up will re-engage it for a time
Shifts from drive to reverse and reverse to drive quickly, 1 & 2 shifts are good. Throttle pressure rod is where I believe it should be. Could it be the shifter not engaging it all the way?
Any ideas? I'm selling this one ( not due to the trans issue ) and want to make it right before it leaves.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: a998 SHIFT ISSUE [Re: Magnumguy] #3192056
11/19/23 05:00 PM
11/19/23 05:00 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Front clutch pack probably fried
Re: a998 SHIFT ISSUE [Re: volaredon] #3192060
11/19/23 05:50 PM
11/19/23 05:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or sealing rings/seals worn or both. Try a can of Trans-X as a Hail Mary.
Re: a998 SHIFT ISSUE [Re: John_Kunkel] #3192063
11/19/23 06:04 PM
11/19/23 06:04 PM
S.E.Ohio
S.E.Ohio
I put a quart of fluid in it although it didn't indicate it was low, made a "shuge" improvement in it, if I let off the gas then back on it slips but then it "catches" and all's well. Still going to try some trans X.
Re: a998 SHIFT ISSUE [Re: Magnumguy] #3192160
11/20/23 10:39 AM
11/20/23 10:39 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Might still be a little low ? Has the wrong dipstick and/or tube ? Though if it's been slipping bad once things get glazed over fan
Re: a998 SHIFT ISSUE [Re: JohnRR] #3192185
11/20/23 12:22 PM
11/20/23 12:22 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Sounds like the inevitable is coming.
R+R time this winter
Re: a998 SHIFT ISSUE [Re: gtx6970] #3192957
11/23/23 08:42 PM
11/23/23 08:42 PM
S.E.Ohio
S.E.Ohio
Well, the issue has changed. Now it shifts into high, but when I left off the gas, it seems to kick out of gear, but when I apply throttle, it kicks back in.
So has what I need to do possibly changed? Band adjustment maybe?
Re: a998 SHIFT ISSUE ( UPDATE ) [Re: Magnumguy] #3193555
11/27/23 07:46 AM
11/27/23 07:46 AM
S.E.Ohio
S.E.Ohio
UPDATE:
After adding TransX, now it engages in 3rd, but when I left off the accelerator, and then back on the gas, it'll act like it's out of gear, then engages. ?
Seems like the faster I'm going, the quicker it re-engages. Thoughts?
Re: a998 SHIFT ISSUE ( UPDATE ) [Re: Magnumguy] #3193599
11/27/23 12:40 PM
11/27/23 12:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This is usually caused by worn governor sealing rings, the rings are metal so no additive can cure this. The rings can be replaced without removing the trans.
Re: a998 SHIFT ISSUE ( UPDATE ) [Re: John_Kunkel] #3193798
11/27/23 11:19 PM
11/27/23 11:19 PM
S.E.Ohio
S.E.Ohio
Great!!! Can those be bought separately?
Re: a998 SHIFT ISSUE ( UPDATE ) [Re: Magnumguy] #3193920
11/28/23 02:46 PM
11/28/23 02:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: a998 SHIFT ISSUE ( UPDATE ) [Re: John_Kunkel] #3194333
11/29/23 11:17 PM
11/29/23 11:17 PM
S.E.Ohio
S.E.Ohio
