a998 SHIFT ISSUE
#3192055
11/19/23 04:54 PM
11/19/23 04:54 PM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
OK, bought this Magnum a couple years ago. Has sat virtually the whole time except for a couple very short runs.
Drove it to the license bureau for a title inspection, and noticed it shifts great, EXCEPT for when it hit 3rd. It acts like it's slipping horribly bad. Drop it back in 2, then back to 3, a couple times it would stay engaged but eventually start to slip
Fearing the worst, but once or twice it did stay engaged for a while. Sometimes dropping it back in 2nd and up will re-engage it for a time
Shifts from drive to reverse and reverse to drive quickly, 1 & 2 shifts are good. Throttle pressure rod is where I believe it should be. Could it be the shifter not engaging it all the way?
Any ideas? I'm selling this one ( not due to the trans issue ) and want to make it right before it leaves.
Re: a998 SHIFT ISSUE
[Re: volaredon]
#3192060
11/19/23 05:50 PM
11/19/23 05:50 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Front clutch pack probably fried Or sealing rings/seals worn or both. Try a can of Trans-X as a Hail Mary.
[Re: Magnumguy]
#3192160
11/20/23 10:39 AM
11/20/23 10:39 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I put a quart of fluid in it although it didn't indicate it was low, made a "shuge" improvement in it, if I let off the gas then back on it slips but then it "catches" and all's well. Still going to try some trans X. Might still be a little low ? Has the wrong dipstick and/or tube ? Though if it's been slipping bad once things get glazed over
Re: a998 SHIFT ISSUE ( UPDATE )
[Re: Magnumguy]
#3193555
11/27/23 07:46 AM
11/27/23 07:46 AM
Magnumguy
S.E.Ohio
UPDATE: After adding TransX, now it engages in 3rd, but when I left off the accelerator, and then back on the gas, it'll act like it's out of gear, then engages. ?
Seems like the faster I'm going, the quicker it re-engages. Thoughts?
[Re: Magnumguy]
#3193599
11/27/23 12:40 PM
11/27/23 12:40 PM
John_Kunkel
Rio Linda, CA
This is usually caused by worn governor sealing rings, the rings are metal so no additive can cure this. The rings can be replaced without removing the trans.
[Re: John_Kunkel]
#3193798
11/27/23 11:19 PM
11/27/23 11:19 PM
Magnumguy
S.E.Ohio
Great!!! Can those be bought separately?
