NEED OIL CHANGE RAMPS #3182133
10/08/23 12:13 PM
10/08/23 12:13 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
SRT Charger/challenger oil change ramps ? Home made or store bought ? Store bought where ? And how high are they? I found a plastic set .. but they are just 2 1/2 inches high ! … worthless! If homemade .. specs and pics please !
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: NEED OIL CHANGE RAMPS [Re: 340SIX] #3182980
10/11/23 08:45 AM
10/11/23 08:45 AM
lyon
fdax Offline
fdax  Offline
lyon
If you wanted to use Jack stands behind the front wheels as extra security for the event that a ramp failed, you could position the ramps behind the front wheels and then back up onto them. Then the ramp does not block the pinch welds behind the front wheels allowing you to place a Jack stand on the driver and passenger sides.
Kodi
Re: NEED OIL CHANGE RAMPS [Re: fdax] #3184374
10/16/23 01:03 PM
10/16/23 01:03 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Maybe it's me, but I wouldn't trust ramps with my life. Are you trying to avoid using a jack? Wood stands under the wheels like these would be best. Keeps the tires from rolling and you don't have to contend with jack stands under the car when changing the oil.
Re: NEED OIL CHANGE RAMPS [Re: MarkZ] #3184389
10/16/23 02:27 PM
10/16/23 02:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have some Rhino ramps 8.5in tall I use for my 2020 T/A 392 Challenger, they work great with a rough surface floor, on smooth floor I drilled holes in the floor & some angle iron & slid the bolts into the slab in front of the ramps to keep them from sliding, the angle iron is not permanent just pull the long bolts out.
Re: NEED OIL CHANGE RAMPS [Re: CSK] #3184794
10/18/23 11:57 AM
10/18/23 11:57 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My Rhino Ramps...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: NEED OIL CHANGE RAMPS [Re: Brad_Haak] #3184870
10/18/23 03:44 PM
10/18/23 03:44 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I have a pair of these ramps (same as the ones in brad's post it looks like) and they work on my '11 charger RT (although I usually just lift it by the front crossmember. have to use the ramps on my daughter's Cherokee, there is no place really to use a floor jack on it.
https://www.amazon.com/RhinoGear-11909ABMI-RhinoRamps-Vehicle-Ramp/dp/B0117EETEK
2017 Grand Cherokee Overland
Re: NEED OIL CHANGE RAMPS [Re: patrick] #3185665
10/22/23 10:47 AM
10/22/23 10:47 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have rhino as well. my old srt 300 was pretty low and i just put a 2x8 to drive on first so i didnt hit the bumper. my other 300 is lowered but not as much and no issues at all, they work really well for oil changes
Re: NEED OIL CHANGE RAMPS [Re: CSK] #3192818
11/23/23 10:49 AM
11/23/23 10:49 AM
south louisiana
lowell66dart Offline
south louisiana
I bought a set from Harbour Freight and they worked with my 2020 Scat WB.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: NEED OIL CHANGE RAMPS [Re: lowell66dart] #3192993
11/24/23 10:35 AM
11/24/23 10:35 AM
BDW Offline
BDW  Offline
Are those wide enough, or do the tires hang off side?
Any way you could measure? Looking for something I can back onto with 275 rear tires.
Rhino ramps states:
12,000 pound GVW (gross vehicle weight) capacity and for use with tires 9" in width (doesn't seem wide enough, even for front tires?)
Thx
Re: NEED OIL CHANGE RAMPS [Re: MarkZ] #3192995
11/24/23 11:09 AM
11/24/23 11:09 AM
BDW Offline
BDW  Offline
Can you jack that in 1 iteration?
Seems like with the suspension drop when the tires come off the ground, you'd need a pretty high lift?
Did something similar, but had to position and adjust jack stands multiple times, to get it high enough.
Kind of a hassle for an oil change, took me 45min just for that multiple step process, and getting it down was time consuming doing it in steps.
Re: NEED OIL CHANGE RAMPS [Re: BDW] #3193023
11/24/23 01:30 PM
11/24/23 01:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Rhino ramps states:
Thx
Mine has 275's on the front no problem at all
Re: NEED OIL CHANGE RAMPS [Re: CSK] #3194039
11/28/23 10:22 PM
11/28/23 10:22 PM
BDW Offline
BDW  Offline
I ended up buying the HF ramps, they had them on Black Friday sale for $45.
They are ok, but my 06 Mustang still comes close to hitting.
I put a foot long 2" x 6"' to drive up before the ramp and that did the trick.
Much easier than my old method of having to drive on the 2x6 just to get the floor jack under, and then jack and place the jack stands.
