Re: NEED OIL CHANGE RAMPS
[Re: 340SIX]
#3182980
10/11/23 08:45 AM
10/11/23 08:45 AM
Posts: 12 lyon
fdax
lyon
If you wanted to use Jack stands behind the front wheels as extra security for the event that a ramp failed, you could position the ramps behind the front wheels and then back up onto them. Then the ramp does not block the pinch welds behind the front wheels allowing you to place a Jack stand on the driver and passenger sides. Kodi
[Re: fdax]
#3184374
10/16/23 01:03 PM
10/16/23 01:03 PM
Posts: 4,418 Michigan
MarkZ
Worthy
Worthy
Maybe it's me, but I wouldn't trust ramps with my life. Are you trying to avoid using a jack? Wood stands under the wheels like these would be best. Keeps the tires from rolling and you don't have to contend with jack stands under the car when changing the oil.
[Re: MarkZ]
#3184389
10/16/23 02:27 PM
10/16/23 02:27 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I have some Rhino ramps 8.5in tall I use for my 2020 T/A 392 Challenger, they work great with a rough surface floor, on smooth floor I drilled holes in the floor & some angle iron & slid the bolts into the slab in front of the ramps to keep them from sliding, the angle iron is not permanent just pull the long bolts out.
[Re: CSK]
#3184794
10/18/23 11:57 AM
10/18/23 11:57 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3184870
10/18/23 03:44 PM
10/18/23 03:44 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I have a pair of these ramps (same as the ones in brad's post it looks like) and they work on my '11 charger RT (although I usually just lift it by the front crossmember. have to use the ramps on my daughter's Cherokee, there is no place really to use a floor jack on it. https://www.amazon.com/RhinoGear-11909ABMI-RhinoRamps-Vehicle-Ramp/dp/B0117EETEK
[Re: CSK]
#3192818
11/23/23 10:49 AM
11/23/23 10:49 AM
Posts: 885 south louisiana
lowell66dart
south louisiana
I bought a set from Harbour Freight and they worked with my 2020 Scat WB.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: lowell66dart]
#3192993
11/24/23 10:35 AM
11/24/23 10:35 AM
Posts: 4,727 Florida
BDW
I bought a set from Harbour Freight and they worked with my 2020 Scat WB. Are those wide enough, or do the tires hang off side? Any way you could measure? Looking for something I can back onto with 275 rear tires. Rhino ramps states: 12,000 pound GVW (gross vehicle weight) capacity and for use with tires 9" in width (doesn't seem wide enough, even for front tires?) Thx
[Re: MarkZ]
#3192995
11/24/23 11:09 AM
11/24/23 11:09 AM
BDW
Maybe it's me, but I wouldn't trust ramps with my life. Are you trying to avoid using a jack? Wood stands under the wheels like these would be best. Keeps the tires from rolling and you don't have to contend with jack stands under the car when changing the oil. Can you jack that in 1 iteration? Seems like with the suspension drop when the tires come off the ground, you'd need a pretty high lift? Did something similar, but had to position and adjust jack stands multiple times, to get it high enough. Kind of a hassle for an oil change, took me 45min just for that multiple step process, and getting it down was time consuming doing it in steps.
[Re: BDW]
#3193023
11/24/23 01:30 PM
11/24/23 01:30 PM
CSK
Pattison Texas
I bought a set from Harbour Freight and they worked with my 2020 Scat WB. Are those wide enough, or do the tires hang off side? Any way you could measure? Looking for something I can back onto with 275 rear tires. Rhino ramps states: 12,000 pound GVW (gross vehicle weight) capacity and for use with tires 9" in width (doesn't seem wide enough, even for front tires?) Thx Mine has 275's on the front no problem at all
