Worked with an odd 727 today
#3192685
11/22/23 05:55 PM
11/22/23 05:55 PM
Posts: 9,847 MI, usa
dvw
MI, usa
A friend works at a facility that builds turbines. This baby has just been freshened and will be run in on the stand with the trans. Modified push button 727. As you can see the front bell housing is no longer there. No converter. No pump. I went over to figure out the shift cable arrangement on the stand. Pretty cool piece. Doug
Re: Worked with an odd 727 today
[Re: 340Cuda]
#3192747
11/22/23 10:15 PM
11/22/23 10:15 PM
dvw
MI, usa
So for a Chrysler Turbine Car? If not what? Thanks! Yes one of the 4 running cars. Doug
[Re: dvw]
#3192753
11/22/23 10:59 PM
11/22/23 10:59 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
That’s awesome! Have you ever seen one of them running in person?
I’ve seen the one at the Henry Ford, and I thought there was one in the Chrysler museum too, but it’s been decades.
[Re: mkdart]
#3192856
11/23/23 12:58 PM
11/23/23 12:58 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Cool stuff you get to be part of for sure.
[Re: mkdart]
#3192960
11/23/23 08:47 PM
11/23/23 08:47 PM
Posts: 144 Missouri
randavis
Missouri
The bank president in the town I lived close to had one of the cars that they tested. I saw the car around town several times. I never saw an engine though.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: volaredon]
#3193006
11/24/23 12:00 PM
11/24/23 12:00 PM
Posts: 3,517 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Does Jay Leno still have one Yes I believe he does although I think he "hot started" his and had to have the engine rebuilt. I have seen an article or Youtube video about the process but don't remember which. Hopefully someone else will know.
[Re: dvw]
#3193113
11/24/23 10:01 PM
11/24/23 10:01 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Very cool! I get it not needing a converter but how could it work without a pump?
[Re: dvw]
#3193252
11/25/23 05:01 PM
11/25/23 05:01 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The turbine has a 900 psi pump that feeds the PS pump. Then it is regulated down to the trans and turbine. This is the same concept used in the original factory Clutch-Flite. Aftermarket builders like B&M improved on it by developing the "spider" that drives the pump via the three clutch pressure plate levers.
