Unbelievable semi crash into Mopar dealership #3189699
11/08/23 08:39 PM
11/08/23 08:39 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Master, again and still
Re: Unbelievable semi crash into Mopar dealership [Re: DaveRS23] #3189735
11/08/23 11:13 PM
11/08/23 11:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
UHH, downshift, turn the key off, emergency brake ? That truck looked like it was MOVING, many are paid by the load around here and are well known for hauling azz
Re: Unbelievable semi crash into Mopar dealership [Re: DaveRS23] #3189747
11/09/23 01:05 AM
11/09/23 01:05 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Can't watch it - BoobTube has me blocked unless I turn off ad blockers. Then I turn them off, still blocked. F-UTube.
Re: Unbelievable semi crash into Mopar dealership [Re: Sunroofcuda] #3189750
11/09/23 01:17 AM
11/09/23 01:17 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yeah, several options to minimize that situation.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Unbelievable semi crash into Mopar dealership [Re: BloFish] #3189754
11/09/23 02:34 AM
11/09/23 02:34 AM
Castlegar, BC, Canada
That AMC Guy Offline
Looks like a pretty flat area to "lose" brakes. And if he'd lost his air supply, if everything was working properly; the whole system should've "dynamited" and basically locked the whole system up. Betcha the driver was a "new" American; inexperienced and panicked.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Unbelievable semi crash into Mopar dealership [Re: TJP] #3189757
11/09/23 04:43 AM
11/09/23 04:43 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
At one point he/she was on the sidewalk still hauling butt. I would have tried all of the things you mentioned AND taken out that row of trees, parked cars that most likely didn't have anyone inside them or anything that would slowed or stopped me that wouldn't have hurt or killed someone. Probably dropped their crack pipe.
Re: Unbelievable semi crash into Mopar dealership [Re: DaveRS23] #3189761
11/09/23 07:31 AM
11/09/23 07:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
WOW
Thankfully. No lives lost
Re: Unbelievable semi crash into Mopar dealership [Re: TJP] #3189762
11/09/23 07:55 AM
11/09/23 07:55 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
I'm thinking he he missed a gear, once you have too much speed it's very hard to get it back in gear, too many RPMs. if you turn the key off you lose steering. Medical issue? Mechanical failure,I didn't see any brake smoke.
America First!
Re: Unbelievable semi crash into Mopar dealership [Re: That AMC Guy] #3189793
11/09/23 11:13 AM
11/09/23 11:13 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yeah, if you lose air the system locks up, that is what an S-Cam is designed for! Only way to lose brakes on a semi is to smoke them, and hard to do that on that many axles... work
JB Rhinehart, Realist
A-Body's RULE!
Re: Unbelievable semi crash into Mopar dealership [Re: Sunroofcuda] #3189796
11/09/23 11:25 AM
11/09/23 11:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Same here.
Re: Unbelievable semi crash into Mopar dealership [Re: carnut68] #3189829
11/09/23 01:21 PM
11/09/23 01:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
hadn't thought about the medical issue, that could be a strong possibility as it was moving frown
Re: Unbelievable semi crash into Mopar dealership [Re: TJP] #3189902
11/09/23 06:24 PM
11/09/23 06:24 PM
Rocky Hill, Ct
Roadcuda Offline
Roadcuda  Offline
Rocky Hill, Ct
While a medical issue is possible I have to wonder because the truck looked under control while on the sidewalk for at least a block, and the driver did try to steer around two groups of stopped cars trying to avoid them. And agreed with what's been said about the brakes. When the air system pressure gets below 60 psi the brake canisters should lock up. That is if they were properly adjusted to begin with.
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
Re: Unbelievable semi crash into Mopar dealership [Re: Sunroofcuda] #3189924
11/09/23 07:44 PM
11/09/23 07:44 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
You (and everyone else) have to keep your adblocker updated, manually. Find out how for the adblock you use
Re: Unbelievable semi crash into Mopar dealership [Re: Sunroofcuda] #3190380
11/12/23 08:50 AM
11/12/23 08:50 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
yea? i've seen a few guys on different boards say that.. i have been running adbllock for many years and have never had any issues on youtube
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Unbelievable semi crash into Mopar dealership [Re: abodyjoe] #3190418
11/12/23 11:58 AM
11/12/23 11:58 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You can click the X and close the message and then play it or watch with out supporting. I wonder why he didn't keep going strait(after he hit the first car) unless there was mechanical problem that made him turn left.
Re: Unbelievable semi crash into Mopar dealership [Re: Moparite] #3190446
11/12/23 02:04 PM
11/12/23 02:04 PM
IMGTX Offline
IMGTX  Offline
I am not a trucker in those big rigs but he seemed to be going way to far without shedding any speed..
The brakes should have worked on some level unless the pedal fell off and if that happened why didn't he downshift? Let off the gas? Etc?
Something seems fishy like he had no idea what he was doing or was doing it on purpose.
shruggy
Re: Unbelievable semi crash into Mopar dealership [Re: IMGTX] #3190514
11/12/23 07:19 PM
11/12/23 07:19 PM
shruggy
I'm no expert by any means either, but as we mentioned before - air brake vehicles kinda work the opposite way hydraulic brakes work. When an Air brake vehicle LOSES it's air supply, the brakes APPLY full force. It's called "Dynamiting". So, unless the actual braking material on the shoes was down to nothing, the idea is that the truck will slow down and/or stop. Worst case, the wheels lock up but that rarely happens. Either way, the truck would stop. I don't see any smoke billowing out from the brakes, so he obviously didn't cook off all his pad material.
There are enough inconsistencies in this situation to fill a warehouse.
It's flat land, the truck was NOT decelerating, the brakes weren't smoking, if he'd lost air - the brakes would've dynamited.... only the most ignorant among us would think there aren't redundant systems already in place to mitigate this kind of situation.
Re: Unbelievable semi crash into Mopar dealership [Re: That AMC Guy] #3190551
11/12/23 11:39 PM
11/12/23 11:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
haven't heard any updates on things which I think is kind of strange shruggy
