Re: Unbelievable semi crash into Mopar dealership
[Re: DaveRS23]
#3189747
11/09/23 01:05 AM
11/09/23 01:05 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Can't watch it - BoobTube has me blocked unless I turn off ad blockers. Then I turn them off, still blocked. F-UTube.
[Re: Sunroofcuda]
#3189750
11/09/23 01:17 AM
11/09/23 01:17 AM
Posts: 16,491 On the run…
BloFish
On the run…
Yeah, several options to minimize that situation.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3189754
11/09/23 02:34 AM
11/09/23 02:34 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
Yeah, several options to minimize that situation. Looks like a pretty flat area to "lose" brakes. And if he'd lost his air supply, if everything was working properly; the whole system should've "dynamited" and basically locked the whole system up. Betcha the driver was a "new" American; inexperienced and panicked.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: TJP]
#3189757
11/09/23 04:43 AM
11/09/23 04:43 AM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
UHH, downshift, turn the key off, emergency brake ? That truck looked like it was MOVING, many are paid by the load around here and are well known for hauling azz At one point he/she was on the sidewalk still hauling butt. I would have tried all of the things you mentioned AND taken out that row of trees, parked cars that most likely didn't have anyone inside them or anything that would slowed or stopped me that wouldn't have hurt or killed someone. Probably dropped their crack pipe.
[Re: TJP]
#3189762
11/09/23 07:55 AM
11/09/23 07:55 AM
Posts: 3,202 Md.
carnut68
Md.
UHH, downshift, turn the key off, emergency brake ? That truck looked like it was MOVING, many are paid by the load around here and are well known for hauling azz I'm thinking he he missed a gear, once you have too much speed it's very hard to get it back in gear, too many RPMs. if you turn the key off you lose steering. Medical issue? Mechanical failure,I didn't see any brake smoke.
America First!
[Re: That AMC Guy]
#3189793
11/09/23 11:13 AM
11/09/23 11:13 AM
Posts: 43,584 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yeah, several options to minimize that situation. Looks like a pretty flat area to "lose" brakes. And if he'd lost his air supply, if everything was working properly; the whole system should've "dynamited" and basically locked the whole system up. Betcha the driver was a "new" American; inexperienced and panicked. Yeah, if you lose air the system locks up, that is what an S-Cam is designed for! Only way to lose brakes on a semi is to smoke them, and hard to do that on that many axles...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Sunroofcuda]
#3189796
11/09/23 11:25 AM
11/09/23 11:25 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Can't watch it - BoobTube has me blocked unless I turn off ad blockers. Then I turn them off, still blocked. F-UTube. Same here.
[Re: carnut68]
#3189829
11/09/23 01:21 PM
11/09/23 01:21 PM
Posts: 15,424 Omaha Ne
TJP
Omaha Ne
UHH, downshift, turn the key off, emergency brake ? That truck looked like it was MOVING, many are paid by the load around here and are well known for hauling azz I'm thinking he he missed a gear, once you have too much speed it's very hard to get it back in gear, too many RPMs. if you turn the key off you lose steering. Medical issue? Mechanical failure,I didn't see any brake smoke. hadn't thought about the medical issue, that could be a strong possibility as it was moving
[Re: TJP]
#3189902
11/09/23 06:24 PM
11/09/23 06:24 PM
Posts: 1,014 Rocky Hill, Ct
Roadcuda
Rocky Hill, Ct
UHH, downshift, turn the key off, emergency brake ? That truck looked like it was MOVING, many are paid by the load around here and are well known for hauling azz I'm thinking he he missed a gear, once you have too much speed it's very hard to get it back in gear, too many RPMs. if you turn the key off you lose steering. Medical issue? Mechanical failure,I didn't see any brake smoke. hadn't thought about the medical issue, that could be a strong possibility as it was moving While a medical issue is possible I have to wonder because the truck looked under control while on the sidewalk for at least a block, and the driver did try to steer around two groups of stopped cars trying to avoid them. And agreed with what's been said about the brakes. When the air system pressure gets below 60 psi the brake canisters should lock up. That is if they were properly adjusted to begin with.
[Re: Sunroofcuda]
#3189924
11/09/23 07:44 PM
11/09/23 07:44 PM
Posts: 1,225 Nor here, Nor there
Dart 500
Nor here, Nor there
Can't watch it - BoobTube has me blocked unless I turn off ad blockers. Then I turn them off, still blocked. F-UTube. You (and everyone else) have to keep your adblocker updated, manually. Find out how for the adblock you use
[Re: Sunroofcuda]
#3190380
11/12/23 08:50 AM
11/12/23 08:50 AM
Posts: 11,079 Berlin, N.J.
abodyjoe
Berlin, N.J.
Can't watch it - BoobTube has me blocked unless I turn off ad blockers. Then I turn them off, still blocked. F-UTube. yea? i've seen a few guys on different boards say that.. i have been running adbllock for many years and have never had any issues on youtube
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: Moparite]
#3190446
11/12/23 02:04 PM
11/12/23 02:04 PM
Posts: 12,235 Looking for a way out of Middl...
IMGTX
I am not a trucker in those big rigs but he seemed to be going way to far without shedding any speed.. The brakes should have worked on some level unless the pedal fell off and if that happened why didn't he downshift? Let off the gas? Etc? Something seems fishy like he had no idea what he was doing or was doing it on purpose.
[Re: IMGTX]
#3190514
11/12/23 07:19 PM
11/12/23 07:19 PM
That AMC Guy
I am not a trucker in those big rigs but he seemed to be going way to far without shedding any speed.. The brakes should have worked on some level unless the pedal fell off and if that happened why didn't he downshift? Let off the gas? Etc? Something seems fishy like he had no idea what he was doing or was doing it on purpose. I'm no expert by any means either, but as we mentioned before - air brake vehicles kinda work the opposite way hydraulic brakes work. When an Air brake vehicle LOSES it's air supply, the brakes APPLY full force. It's called "Dynamiting". So, unless the actual braking material on the shoes was down to nothing, the idea is that the truck will slow down and/or stop. Worst case, the wheels lock up but that rarely happens. Either way, the truck would stop. I don't see any smoke billowing out from the brakes, so he obviously didn't cook off all his pad material. There are enough inconsistencies in this situation to fill a warehouse. It's flat land, the truck was NOT decelerating, the brakes weren't smoking, if he'd lost air - the brakes would've dynamited.... only the most ignorant among us would think there aren't redundant systems already in place to mitigate this kind of situation.
