TTI complete exhaust systems #3188634
11/03/23 10:12 PM
11/03/23 10:12 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Anyone ever buy a complete system, not just headers ?
How did it fit up ?
I have an E-body with the leaf springs moved in with the offset hangers, I was looking at the 2 1/2 inch system.
Re: TTI complete exhaust systems [Re: hemienvy] #3188635
11/03/23 10:26 PM
11/03/23 10:26 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I just installed their headers and a full 3" system on my 67 Belvedere and it fit so nice that I have a 2 1/2" manifolds back system on the way for my 66 Coronet.
Re: TTI complete exhaust systems [Re: IROC78] #3188636
11/03/23 10:40 PM
11/03/23 10:40 PM
BDW Offline
BDW  Offline
10yrs ago I put a complete 2.5" system in my Challenger, 340, w/Dr Diff relocation kit, no issues.
Just swapped in a 5.7, bought the TTI shortie headers and head pipes, and it bolted up perfectly to the existing system.
TTI is 1 of the few vendors that you get your monies worth, quality product.
I will say, I didn't spend the $400 they wanted for tips, got some for 1/2 that.
Re: TTI complete exhaust systems [Re: IROC78] #3188637
11/03/23 10:40 PM
11/03/23 10:40 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Put a full 3" X pipe TTI on our 70 Charger, went on like a breeze.
A little maneuvering needed next to the tank, but not too bad.
Joe
Re: TTI complete exhaust systems [Re: jlatessa] #3188638
11/03/23 10:47 PM
11/03/23 10:47 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Put the 2-1/2" system on my '66 Charger in 2005 or so. Went on pretty good. Some Never-Seize and a big rawhide hammer were helpful. wrench hammer
Re: TTI complete exhaust systems [Re: bobby66] #3188654
11/04/23 12:08 AM
11/04/23 12:08 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
I bought and installed TTi’s 304 stainless steel complete exhaust system from manifold to tail pipes on my 69 Charger, it went on perfectly. This was 10 years ago, still looks brand new today. I’ll never have to worry about rust.
To get it in 304 stainless steel, you have to call TTi’s and order it in there slow time which is now.
Re: TTI complete exhaust systems [Re: hemienvy] #3188669
11/04/23 07:55 AM
11/04/23 07:55 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I have a 3" system w/Dr Diff relocation kit, no issues but it is close on my Challenger.
Cuda's have fitment issues with offset hangers.
Re: TTI complete exhaust systems [Re: RTSE4ME] #3188670
11/04/23 08:06 AM
11/04/23 08:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Total 2 1/2" TTI system including headers on my small block 73 Challenger 4 speed. Had to rework the reverse shift rod as it hit the crossover. Apparently later Challenger 4 speeds have a diiferent reverse rod than earlier models. ts been on the car since 2004. Though I've recoated the headers for cosmetic purposes, the system is in great shape. Everything else bolted up perfectly.
Doug
Re: TTI complete exhaust systems [Re: dvw] #3188729
11/04/23 01:04 PM
11/04/23 01:04 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
1 tip, make sure you read every note for the type of car, engine size, heads, transmission, X or H pipe and pipe size for the car you are putting it in...Like other have said, easy install if you get the correct system.
My Monster are real!
Living within your means makes life pretty easy.
Re: TTI complete exhaust systems [Re: 67vertman] #3188734
11/04/23 02:12 PM
11/04/23 02:12 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Would it be wise to call them and have them help you select the right system?
Re: TTI complete exhaust systems [Re: Sniper] #3188839
11/05/23 02:25 AM
11/05/23 02:25 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I put a complete system on my '65 Belvedere, headers to tips. Best fitting, easiest install I have ever done. Everything fit perfectly and just bolted up. up
Re: TTI complete exhaust systems [Re: Ramrod39] #3189022
11/05/23 09:55 PM
11/05/23 09:55 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I bought the 3" X pipe system for my 70 Cuda /gen 2 Hemi /auto and it went on like a breeze. I had the TTI headers on already, and I used the offset DR. Diff kit to put a B-body Dana in. Several years ago I put the same system on my 69 Satelite with a 493/auto with the same results. The only cuts we had to make was on the headpipe/collector adapter to shorten the headpipes by about 3 inches.
Re: TTI complete exhaust systems [Re: Sniper] #3189079
11/06/23 11:46 AM
11/06/23 11:46 AM
Morgan Hill, CA
ackpht Offline
ackpht  Offline
Morgan Hill, CA
I've done two B-bodies, one 2-1/2" and one 3". Install was about as painless as it could be.
The 3" pipes get kinda cozy with the gas tank, but that's geometry.
Re: TTI complete exhaust systems [Re: ackpht] #3189100
11/06/23 01:30 PM
11/06/23 01:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My only negative experience is with A body tailpipes , they aren't bent to use the stock hanger locations.
Re: TTI complete exhaust systems [Re: hemienvy] #3189254
11/07/23 02:15 AM
11/07/23 02:15 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
3" H-pipe on the '71 Charger. Only had to cut a bit off the H-pipe so the tubes are a bit closer, but this is with Hooker headers and the TTI collector adaptors.
2-1/2 X-pipe on the '69 Coronet. The X-pipe to the mufflers seemed to be too long? Maybe for those running shorter mufflers? Had to cut the ends a bit shorter.
Changing the clutch in the Coronet, getting the exhaust back off was a chore. When I put it back, I welded flanges between the mufflers and tail pipes so I can drop the entire center part of the exhaust system.
Have another 2-1/2 H-pipe system for another '69 Coronet, but it is not installed yet.
Re: TTI complete exhaust systems [Re: hemienvy] #3189369
11/07/23 02:29 PM
11/07/23 02:29 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My '73 Challenger has a full tti x-system from 2" RB headers thru 3" exhaust to their stainless-steel tips. I re-installed it a couple of months ago as part of putting my car back together and it was relatively straight forward (again).
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: TTI complete exhaust systems [Re: Brad_Haak] #3190336
11/11/23 09:43 PM
11/11/23 09:43 PM
JCFcuda Offline
JCFcuda  Offline
1973 Barracuda 3 in went together great everything lines up,The only thing that thew me ,there were no note , that if it was a barrracuda you needed to cut the tailpipe 2 in ,of course the system would fit the Challenger perfectly.
Jim F
Re: TTI complete exhaust systems [Re: hemienvy] #3190448
11/12/23 02:28 PM
11/12/23 02:28 PM
How did it fit up ?
I highly recommend the 3.0 or maybe even a 3.5 inch devil complete system over a 2.0, 2 1/4 or 2.5 inch system twocents
Been there, done that, larger is better when it comes to exhaust system with mufflers scope up twocents
Re: TTI complete exhaust systems [Re: Cab_Burge] #3190767
11/14/23 08:40 AM
11/14/23 08:40 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Cab - TTI doesn't offer bigger than 3.0", unfortunately
Re: TTI complete exhaust systems [Re: Brad_Haak] #3191106
11/15/23 01:50 PM
11/15/23 01:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I recently emailed them to see if they had the ability to make a 3.5" system(to the muffler) and they said they couldn't frown
68 Barracuda Formula S 340
