Re: TTI complete exhaust systems
[Re: IROC78]
#3188636
11/03/23 10:40 PM
11/03/23 10:40 PM
Posts: 4,740 Florida
BDW
10yrs ago I put a complete 2.5" system in my Challenger, 340, w/Dr Diff relocation kit, no issues. Just swapped in a 5.7, bought the TTI shortie headers and head pipes, and it bolted up perfectly to the existing system. TTI is 1 of the few vendors that you get your monies worth, quality product.
I will say, I didn't spend the $400 they wanted for tips, got some for 1/2 that.
[Re: RTSE4ME]
#3188670
11/04/23 08:06 AM
11/04/23 08:06 AM
Posts: 9,858 MI, usa
dvw
MI, usa
Total 2 1/2" TTI system including headers on my small block 73 Challenger 4 speed. Had to rework the reverse shift rod as it hit the crossover. Apparently later Challenger 4 speeds have a diiferent reverse rod than earlier models. ts been on the car since 2004. Though I've recoated the headers for cosmetic purposes, the system is in great shape. Everything else bolted up perfectly. Doug
[Re: dvw]
#3188729
11/04/23 01:04 PM
11/04/23 01:04 PM
Posts: 4,776 Star Idaho
67vertman
Star Idaho
1 tip, make sure you read every note for the type of car, engine size, heads, transmission, X or H pipe and pipe size for the car you are putting it in...Like other have said, easy install if you get the correct system.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3188734
11/04/23 02:12 PM
11/04/23 02:12 PM
Posts: 6,290 nowhere
Sniper
nowhere
1 tip, make sure you read every note for the type of car, engine size, heads, transmission, X or H pipe and pipe size for the car you are putting it in...Like other have said, easy install if you get the correct system. Would it be wise to call them and have them help you select the right system?
[Re: Sniper]
#3189079
11/06/23 11:46 AM
11/06/23 11:46 AM
Posts: 3,104 Morgan Hill, CA
ackpht
Morgan Hill, CA
I've done two B-bodies, one 2-1/2" and one 3". Install was about as painless as it could be.
The 3" pipes get kinda cozy with the gas tank, but that's geometry.
[Re: ackpht]
#3189100
11/06/23 01:30 PM
11/06/23 01:30 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
My only negative experience is with A body tailpipes , they aren't bent to use the stock hanger locations.
[Re: hemienvy]
#3189369
11/07/23 02:29 PM
11/07/23 02:29 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My '73 Challenger has a full tti x-system from 2" RB headers thru 3" exhaust to their stainless-steel tips. I re-installed it a couple of months ago as part of putting my car back together and it was relatively straight forward (again).
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: hemienvy]
#3190448
11/12/23 02:28 PM
11/12/23 02:28 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Anyone ever buy a complete system, not just headers ?
How did it fit up ?
I have an E-body with the leaf springs moved in with the offset hangers, I was looking at the 2 1/2 inch system. I highly recommend the 3.0 or maybe even a 3.5 inch complete system over a 2.0, 2 1/4 or 2.5 inch system Been there, done that, larger is better when it comes to exhaust system with mufflers
[Re: Cab_Burge]
#3190767
11/14/23 08:40 AM
11/14/23 08:40 AM
Brad_Haak
Loudoun County, VA
Cab - TTI doesn't offer bigger than 3.0", unfortunately
[Re: Brad_Haak]
#3191106
11/15/23 01:50 PM
11/15/23 01:50 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Cab - TTI doesn't offer bigger than 3.0", unfortunately I recently emailed them to see if they had the ability to make a 3.5" system(to the muffler) and they said they couldn't
68 Barracuda Formula S 340
