Locking dipsticks for 727 #3186086
10/24/23 06:08 AM
10/24/23 06:08 AM
MN
JERICOGTX Offline OP
MN
What is everyone using for a locking dipstick for their 727, BESIDES a Lokar setup? Looking for a budget setup, for my nephew.
Thanks.
69 GTX 68 Road Runner
Re: Locking dipsticks for 727 [Re: JERICOGTX] #3186087
10/24/23 06:18 AM
10/24/23 06:18 AM
tboomer Offline
tboomer  Offline
Jeff...Om my old 64 I got a GM one from a junkyard...I can't remember what year but it was a truck one I cut down. up
Re: Locking dipsticks for 727 [Re: tboomer] #3186093
10/24/23 07:48 AM
10/24/23 07:48 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
https://www.amazon.com/ATI-Performance-Products-726491-Dipstick/dp/B003NF2HGE
I went with this one. Junkyard would be cheaper for sure but this was the cheapest one I could find new.
Re: Locking dipsticks for 727 [Re: Blusmbl] #3186097
10/24/23 08:18 AM
10/24/23 08:18 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I just made a positive lock for the Lokar one. The rule changed a season or 2 ago, we needed to keep the flexible dipstick tube due to the CSR shield, the push lock was insufficient according to the rulebook and the techs were happy with it so all good.
Re: Locking dipsticks for 727 [Re: Tig] #3186099
10/24/23 08:26 AM
10/24/23 08:26 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
zip tie ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Locking dipsticks for 727 [Re: bigdad] #3186119
10/24/23 09:32 AM
10/24/23 09:32 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted by bigdad
zip tie ..
That would work grin up
Re: Locking dipsticks for 727 [Re: bigdad] #3186122
10/24/23 09:38 AM
10/24/23 09:38 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
zip tie ..
I got groused at by a tech inspector for that recently. This may be the solution...
'63 Dodge 330
11.19 @ 121 mph
Re: Locking dipsticks for 727 [Re: Blusmbl] #3186139
10/24/23 10:59 AM
10/24/23 10:59 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I believe this is the one I have: https://www.manciniracing.com/man727diptub.html
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Locking dipsticks for 727 [Re: Brad_Haak] #3186141
10/24/23 11:03 AM
10/24/23 11:03 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I used the ATI locking plug for years but it doesn't have a dip stick , my dip stick tubes always seemed to leak by the trans. At Carlisle last year I bought an A&A dip stick and tube it fits nice and tight , no more leaks and it has the dip stick and locking handle.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Locking dipsticks for 727 [Re: Brad_Haak] #3186143
10/24/23 11:10 AM
10/24/23 11:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought that one and tried to install. I was less than happy with the rubber seal fitment at the bottom so it hangs on my wall.
'63 Dodge 330
11.19 @ 121 mph
Re: Locking dipsticks for 727 [Re: GY3] #3186157
10/24/23 12:27 PM
10/24/23 12:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I safety wire mine down. It has passed NHRA tech staff before.
68 Barracuda Formula S 340
Re: Locking dipsticks for 727 [Re: Bad340fish] #3186158
10/24/23 12:33 PM
10/24/23 12:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use the same style one as Mancini sells...Not any issues with it and all clears the CSI shield.
Re: Locking dipsticks for 727 [Re: Al_Alguire] #3186159
10/24/23 12:38 PM
10/24/23 12:38 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
GM car at the junkyard...FREE
grin
....BAD A$$ STREET CAR.....
Re: Locking dipsticks for 727 [Re: n20mstr] #3186199
10/24/23 03:26 PM
10/24/23 03:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Every time I’m at Pic-Part I get one off a Chevy truck or van, $0, I wound it it up stick in in the bag. Checkout lady says no charge. Get the right amount of oil in trans then cut new stick about same length, stick in and where the fluid shows make a good mark, done.
Re: Locking dipsticks for 727 [Re: GY3] #3186272
10/24/23 08:21 PM
10/24/23 08:21 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I have rhos on two different cars. The one w/o the shield was simple. With the shield it took a little finessing. Trim rhe bracket and slightly change the bracket angle. Took about 10 extra minutes.
Ok
Re: Locking dipsticks for 727 [Re: cudaman1969] #3186321
10/25/23 01:41 AM
10/25/23 01:41 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
This. And it's cheap and works.
America First!
Re: Locking dipsticks for 727 [Re: carnut68] #3186333
10/25/23 07:27 AM
10/25/23 07:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A couple isssues with the GM stick. First the calibration is off. Easily remidied by drilling out the rivet holding the unit together. Then take a stock mopar stick and cut the top off. Grind it down to the GM width. Then drill a hole and use a small bolt and nut with loctite to put it back together. The bigger issue is that the GM tube is slightly smaller in diameter. It won't really lock. A single wrap of electrical tape around the rubber is enought to tighten it up. But eventially a new piece of tape is needed. This winter I'm going to build a swedge to shink the top of the tube.
Doug
Re: Locking dipsticks for 727 [Re: JERICOGTX] #3186345
10/25/23 09:41 AM
10/25/23 09:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The one in the Mancini link has the larger seal you DEFINITELY want!
Re: Locking dipsticks for 727 [Re: Brad_Haak] #3186397
10/25/23 12:33 PM
10/25/23 12:33 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Correction: I have one that's designed to work w/ a CSR shield: https://www.coperacingtrans.com/?product=727-big-block-stick-tube-wcsr-shield
I don't recall if I got it from Cope, but I definitely have that model... probably did since I got the shield from Cope when he had one while everyone else was waiting for orders to be filled.
Re: Locking dipsticks for 727 [Re: Brad_Haak] #3187023
10/28/23 01:03 PM
10/28/23 01:03 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I just checked both of the ones I got off the GMC trucks, both fit nice. Easy in and after locked it won’t come out. If pics are needed I can supply.
