Locking dipsticks for 727
#3186086
10/24/23 06:08 AM
10/24/23 06:08 AM
Posts: 10,032 MN
JERICOGTX
MN
What is everyone using for a locking dipstick for their 727, BESIDES a Lokar setup? Looking for a budget setup, for my nephew.
Thanks.
69 GTX
68 Road Runner
Re: Locking dipsticks for 727
[Re: Blusmbl]
#3186097
10/24/23 08:18 AM
10/24/23 08:18 AM
Posts: 2,924 A shed in England
Tig
A shed in England
I just made a positive lock for the Lokar one. The rule changed a season or 2 ago, we needed to keep the flexible dipstick tube due to the CSR shield, the push lock was insufficient according to the rulebook and the techs were happy with it so all good.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: bigdad]
#3186119
10/24/23 09:32 AM
10/24/23 09:32 AM
Tig
A shed in England
That would work
[Re: bigdad]
#3186122
10/24/23 09:38 AM
10/24/23 09:38 AM
Posts: 4,684 Wichita
GY3
Wichita
I got groused at by a tech inspector for that recently. This may be the solution...
[Re: Blusmbl]
#3186139
10/24/23 10:59 AM
10/24/23 10:59 AM
Posts: 1,144 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3186141
10/24/23 11:03 AM
10/24/23 11:03 AM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
I used the ATI locking plug for years but it doesn't have a dip stick , my dip stick tubes always seemed to leak by the trans. At Carlisle last year I bought an A&A dip stick and tube it fits nice and tight , no more leaks and it has the dip stick and locking handle.
[Re: Brad_Haak]
#3186143
10/24/23 11:10 AM
10/24/23 11:10 AM
GY3
Wichita
I bought that one and tried to install. I was less than happy with the rubber seal fitment at the bottom so it hangs on my wall.
[Re: GY3]
#3186157
10/24/23 12:27 PM
10/24/23 12:27 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I safety wire mine down. It has passed NHRA tech staff before.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3186158
10/24/23 12:33 PM
10/24/23 12:33 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
I use the same style one as Mancini sells...Not any issues with it and all clears the CSI shield.
[Re: GY3]
#3186272
10/24/23 08:21 PM
10/24/23 08:21 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I bought that one and tried to install. I was less than happy with the rubber seal fitment at the bottom so it hangs on my wall. I have rhos on two different cars. The one w/o the shield was simple. With the shield it took a little finessing. Trim rhe bracket and slightly change the bracket angle. Took about 10 extra minutes.
Ok
[Re: cudaman1969]
#3186321
10/25/23 01:41 AM
10/25/23 01:41 AM
Posts: 3,199 Md.
carnut68
Md.
Every time I’m at Pic-Part I get one off a Chevy truck or van, $0, I wound it it up stick in in the bag. Checkout lady says no charge. Get the right amount of oil in trans then cut new stick about same length, stick in and where the fluid shows make a good mark, done. This. And it's cheap and works.
America First!
[Re: carnut68]
#3186333
10/25/23 07:27 AM
10/25/23 07:27 AM
Posts: 9,847 MI, usa
dvw
MI, usa
A couple isssues with the GM stick. First the calibration is off. Easily remidied by drilling out the rivet holding the unit together. Then take a stock mopar stick and cut the top off. Grind it down to the GM width. Then drill a hole and use a small bolt and nut with loctite to put it back together. The bigger issue is that the GM tube is slightly smaller in diameter. It won't really lock. A single wrap of electrical tape around the rubber is enought to tighten it up. But eventially a new piece of tape is needed. This winter I'm going to build a swedge to shink the top of the tube. Doug
[Re: Brad_Haak]
#3186397
10/25/23 12:33 PM
10/25/23 12:33 PM
Brad_Haak
Loudoun County, VA
Correction: I have one that's designed to work w/ a CSR shield: https://www.coperacingtrans.com/?product=727-big-block-stick-tube-wcsr-shieldI don't recall if I got it from Cope, but I definitely have that model... probably did since I got the shield from Cope when he had one while everyone else was waiting for orders to be filled.
