10/13/23 11:33 PM
10/13/23 11:33 PM
Kansas
Thelma133 Offline OP
Kansas
My cuda has a problem lurching /creeping forward occasionally when trans brake button is pushed.
1) fluid level ok, good color, no burnt smell.
2) I believe it has a griner brake after talking to Dave at pro trans.
3) Lupo converter, new
I have checked and replaced some of the wiring at the solenoid and have 12 volts. After a pass, sometimes the brake won’t hold the car at all. I have googled the hell out of this question, but most of the answers are power glide related. Car backs up fine and still shifts through all 3 gears normally. I have not pulled pan off yet. Any of you had this problem before?
Re: 727 [Re: Thelma133] #3183814
10/14/23 02:26 AM
10/14/23 02:26 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Keith Long bought Griner's stuff after he passed. Give him a call. Keith Cell
Mobile (219) 718-35four two.
Re: 727 [Re: slantzilla] #3183829
10/14/23 08:39 AM
10/14/23 08:39 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The lip seal on the piston flips or a section of the seal comes off allowing a pressure leak.
Re: 727 [Re: fbs63] #3183830
10/14/23 08:45 AM
10/14/23 08:45 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Not sure about exactly how the brake operates, but simply you hold the trans in reverse and low at the same time release reverse and away you go. Put a pressure gauge on it, 727 is blessed with a port for every circuit, any internal leaks should show up. And if you are getting help over the phone those pressure numbers will help with the advice, they give you.
Re: 727 [Re: Thelma133] #3183841
10/14/23 10:13 AM
10/14/23 10:13 AM
A727Tflite Offline
A727Tflite  Offline
x
Re: 727 [Re: A727Tflite] #3183860
10/14/23 11:42 AM
10/14/23 11:42 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
The most common issue I have found is the reverse spool in the VB sticks due to debris (fines from wear). I used to double hit the Brake button to help but routine cleaning was the only insurance to prevent it...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 727 [Re: A727Tflite] #3183862
10/14/23 11:44 AM
10/14/23 11:44 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In 1st gear the rear clutch and lower roller and/or rear band are applied. When engaging the brake the forward clutch is applied. If it creaps forward my feeling is the low roller isn't set or the rear band isn't holding sufficiently.
Doug
Re: 727 [Re: Thelma133] #3183884
10/14/23 12:35 PM
10/14/23 12:35 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I am guessing you may have have an older Turbo action brake or something similar - they were known to do that - Try bringing the idle up before you set it
Re: 727 [Re: DoubleD] #3183892
10/14/23 01:06 PM
10/14/23 01:06 PM
Do you mean raised the RPM in low gear before applying the trans brake confused work I've had to do that on several other brands of early trans brakes rant whiney
Re: 727 [Re: Cab_Burge] #3183904
10/14/23 02:08 PM
10/14/23 02:08 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Bring the RPMs up - like 2500 - before you roll into the bottom bulb. It takes awhile for the fluid to fill those areas otherwise.
Old TA brakes did that and their instructions included this info. Never had an issue with a Griner, even on a pro tree.
Clearances and spring load in the high drum clutch pack can be adjusted also.
Re: 727 [Re: slantzilla] #3183941
10/14/23 03:48 PM
10/14/23 03:48 PM
Kansas
Kansas
Thanks for the tips
Re: 727 [Re: Thelma133] #3183944
10/14/23 03:53 PM
10/14/23 03:53 PM
Kansas
Kansas
As an aside, I have never had to raise the idle up to make the Transbrake function normally. This issue has just started to happen gradually. Guess I’ll have to pull it out and have it checked.
Re: 727 [Re: Thelma133] #3184017
10/14/23 10:06 PM
10/14/23 10:06 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
I had a similar issue with my griner LBA transbrake. "Keith" told me the rear band wasn't adjusted tight enough. If memory serves he said it needed to be 1/16 to 3/16 play at the servo arm. Haven't had a problem since . Hope this helps.
Re: 727 [Re: A727Tflite] #3184337
10/16/23 10:10 AM
10/16/23 10:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Any time I had a slight “creep” (car moves forward slightly when brake applied) usually a new set f Teflon pump stator seals were in order. That was with my Tranz-act & Griner.
