Re: 727
[Re: Thelma133]
#3183814
10/14/23 02:26 AM
10/14/23 02:26 AM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Keith Long bought Griner's stuff after he passed. Give him a call. Keith Cell Mobile (219) 718-35four two.
Re: 727
[Re: A727Tflite]
#3183860
10/14/23 11:42 AM
10/14/23 11:42 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
The most common issue I have found is the reverse spool in the VB sticks due to debris (fines from wear). I used to double hit the Brake button to help but routine cleaning was the only insurance to prevent it...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 727
[Re: Cab_Burge]
#3183904
10/14/23 02:08 PM
10/14/23 02:08 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Bring the RPMs up - like 2500 - before you roll into the bottom bulb. It takes awhile for the fluid to fill those areas otherwise.
Old TA brakes did that and their instructions included this info. Never had an issue with a Griner, even on a pro tree.
Clearances and spring load in the high drum clutch pack can be adjusted also.
