Cervini shaker hood kit #3180597
10/03/23 02:13 PM
10/03/23 02:13 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Has anyone tried one of these? Issues ? Thoughts .
Are the factory hoods glass ?
Re: Cervini shaker hood kit [Re: Wirenut] #3180614
10/03/23 02:45 PM
10/03/23 02:45 PM
IMGTX Offline
IMGTX  Offline
I have not tried the kit but the factory hoods were metal.
Nearly all mopar hoods were metal. AAR, T/A, six pack road runner & coronets (1969 only I believe, feel free to correct), and the Chrysler 300 Hurst edition are the only fiberglass ones I remember on production cars.
Probably more I do not know but not many.
Re: Cervini shaker hood kit [Re: IMGTX] #3180618
10/03/23 02:54 PM
10/03/23 02:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Then you have aluminum hoods in '63 and '64.
'63 Dodge 330
11.19 @ 121 mph
Re: Cervini shaker hood kit [Re: GY3] #3180744
10/03/23 08:56 PM
10/03/23 08:56 PM
IMGTX Offline
IMGTX  Offline
Yes I forgot those. up
Re: Cervini shaker hood kit [Re: IMGTX] #3180916
10/04/23 12:03 PM
10/04/23 12:03 PM
moparx Offline
moparx  Offline
aluminum is "metal". biggrin
sorry, i couldn't resist...................
beer
Re: Cervini shaker hood kit [Re: moparx] #3180925
10/04/23 12:24 PM
10/04/23 12:24 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have also been looking to convert my 12' to a Shaker hood to match my 70.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cervini shaker hood kit [Re: Wirenut] #3181071
10/04/23 07:08 PM
10/04/23 07:08 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
they have been making high quality hoods for mustangs forever, don't see why quality wouldn't be there for challengers too..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Cervini shaker hood kit [Re: abodyjoe] #3181074
10/04/23 07:17 PM
10/04/23 07:17 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
we put one on my sons 2013 rt challenger high quality,fit&finish very good,&it has a cold air intake that works.
Re: Cervini shaker hood kit [Re: GarageDodge] #3181291
10/05/23 10:46 AM
10/05/23 10:46 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks . Do you think it’s much heavier than the stock hood?
Re: Cervini shaker hood kit [Re: Wirenut] #3181323
10/05/23 12:18 PM
10/05/23 12:18 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Stock factory Challenger hoods are aluminum
Re: Cervini shaker hood kit [Re: Wirenut] #3181334
10/05/23 12:48 PM
10/05/23 12:48 PM
IMGTX Offline
IMGTX  Offline
Sorry I thought you were asking about the Gen 1 Challengers not the Gen 3.
My bad.
Re: Cervini shaker hood kit [Re: IMGTX] #3181491
10/05/23 07:45 PM
10/05/23 07:45 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Yes it is about 30 lbs more,than stock hood.
Re: Cervini shaker hood kit [Re: Wirenut] #3181515
10/05/23 09:28 PM
10/05/23 09:28 PM
Charlton,Ma
Adm413 Offline
Adm413  Offline
Charlton,Ma
I put one of these hood kits on my 09 SRT within a year of buying it new, so it is now 13+ years old. It is a good quality kit but I have had a couple issues. First was that it was damaged during shipping. I refused it and sent it back and they immediately sent me a new one. Good service on their part. I bought it color match painted and it did match perfectly. The bad issues I had with it are original shaker screws attaching the base plate to the top would vibrate loose. I had to replace them with screws and lock washers and have had no issues since. The other issue is the base plate for the shaker has pedestals that sit on top of intake. They are molded plastic and the engine heat with the combination of the shaker scoop weight caused them to bow down. So the driver side with the tallest pedestal sags down and the shaker now is a little tilted. I have thought about seeing if I could order just the base to fix it but just haven't gotten around to that. I'm not sure if Cervini's has had an issue with other ones or not but it is possible they may have strengthened that design. Overall I have been happy with the hood. I bought this kit before Mopar even came out with the shaker on these newer Chalengers. Here is my red one next to a factory shaker car.
1970 GTX 440/727, B5/B5 1970 Barracuda conv. 318/3spd, EW1/R4 1974 Cuda 383/727, FM3/X9 1971 Barracuda 318/727, GK6/X9 1966 Coronet 500 413/727,White/Black 2010 Challenger SRT 6.1/6Spd, Tor-red/black
Re: Cervini shaker hood kit [Re: GarageDodge] #3181705
10/06/23 02:23 PM
10/06/23 02:23 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Wow . More than I would have thought.
Re: Cervini shaker hood kit [Re: Adm413] #3181706
10/06/23 02:24 PM
10/06/23 02:24 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks for sharing . Found a really good deal on one locally, but maybe I should hold out for oem
